Picture files in AutoCad??
Is there any way to load background images in autocad 2000; ie, 3-views? rather than print out the drawings and scale them up using a ruler and lots of calculations, I think it would be a lot easier to "trace" the basic outlines, scale to the size i'm after, then add structure. Just a thought. It would save on a lot of printer paper in some cases.
I use a program for creating aircraft in FMS (Flying Model Simulator) called Metasequoia which allows this function.
CA
RE: Picture files in AutoCad??
Top menu; Insert/Raster Image; then choose the type of file. The default is to all raster formats so narrowing it down helps. You should know a couple of distances on the image file such as the thickness of several types of materials or a rectangle so you can scale the image to the correct size. You may also have to rotate it a bit to get true horizontal lines. Much easier when using the "ortho" lock.
When you have everything all outlined you will still have to go back through and justify everything.
With three views it's not so bad.
thanks heaps socal! these forums are worth their weight in gold. Thats exactly what i was after.
I was thinking that if I used a 1mm gridsnap for the straight lines everything should come out pretty clean and accurate.
- Dave
- Dave
I like it! This is my first couple of hours mucking around with it. 1/3 scale Tigermoth. The first pic is with the 3-view showing, the second with it hidden. I've moved the wings off their origional position to bring them closer to the rest of the drawing.
CA
Dave, Think you've got it. Use zero line widths when using poly lines. I use ortho rather than a grid as a fine grid can mess up the regens. On the poly lines use the arc and second point feature then back to a line when required.
Guess you could use a section of a fine grid if you keep moving it under where you are working. I also use a center line on ribs and stringers as a model seldom has the same with for these structures.
no grids, use polar and auto snap!
on ribs i use pset to out line it then use arcs and trim to make the outside comes out very accurate if u use ehough points (more points around sharp curves)
now... do it in 3D
btw, exactly how much does this forum weigh?
oh... and the absolute BEST part about that... you can scale the image and dont have to scale each individual measurment!!!!!!!
now... do it in 3D
