Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Asymmetric Airplane Design
Reply
Old 10-12-2004, 07:28 AM
Radil
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Asymmetric Airplane Design
Hey guys....
I was watching Rutan's Boomerang and when I just knew how stable that asymmetric airplane is, i just got amazed. Idea is to make the so called dangerous "Twin-Engine" airplane safer and more stable. I ve seen the propeller effects -- secondary moments and whirling slipstream destabilizing the airplane... in longitudnal and lateral axis in conventional symmetric airplanes.
But IS A Good asymmetric airplane really more stable than a normal symmetric one ? If its YES, Why are they not going for such designs ?
Can you guys explain the reasons why boomerang just needs a liitle aileron in single engine power-off condition.
I think it doesnt even need rudder application wen engine off condition.
Radil is offline
Old 10-12-2004, 12:10 PM
SoCal GliderGuider
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Asymmetric Airplane Design
Rutan's designs use alien technology.
SoCal GliderGuider is offline
Old 10-12-2004, 12:31 PM
Tall Paul
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Rutan has stomped the box into the ground!
He's so far outside that thing it's unbelievable.
As for why such designs aren't common... check the dismal history of the Starship.
Tall Paul is offline
Old 10-12-2004, 07:04 PM
SST
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The Blohm & Voss BV144 was a single engined asymmetrical design that flew well, but pilots, both Allied & German, never took it seriously
SST is offline
Old 10-12-2004, 07:56 PM
air farce one
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Old habbits die hard! If you were joe public and had the money to buy the airplane(which is what the typical corporate aircraft owner is) but lacked the knowledge to understand why it was such a good design, you would probably buy a King air or jet instead of that hideous looking thing.
air farce one is offline
Old 10-13-2004, 10:14 AM
Radil
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
haha, tats true dude. Thank u
Radil is offline
Old 10-16-2004, 09:37 PM
jester1a
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That's the Bloom & Voss 141. I have a 1/12 scale combat ship of it and it flies surprisingly well AND there's no mistaking it for the other planes in the air!
JESTER
jester1a is offline
Old 03-08-2019, 10:33 PM
Richbailey
Hello . Am building a Blohm & Voss 215
Richbailey is offline
Old 03-12-2019, 09:15 PM
BMatthews
BMatthews's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Where do you get the idea that an asymmetric design is MORE stable than a symmetric one? Just because Rutan and B&V have made a few doesn't mean that there's no non symmetric traits to flying them.
Consider too that a lot of full size aircraft fly mostly in straight lines at set airspeeds because the point of them is to move efficiently from A to B. So an asymmetric design can be tweaked to be neatly stable at a typical cruise speed and altitude. But the rest of the time perhaps there's some trim needed to fly at other than this trimmed airspeed.
And for sure asymmetric or not the CG has to be in line with the wing's lifting area or there will be a constant roll input. Now if there IS some slight shift of the CG to compensate for prop torque at some given power level that's one thing. Or one COULD trim the spanwise CG location by shifting fuel instead of using trim. That might work well actually as it would allow for altering the CG for climb power then trim it again for setting up the cruise.
But really other than these and perhaps a few other unique traits there's really nothing to suggest that asymmetric aircraft would be any more or less stable than other more traditional shapes.
BMatthews is offline
