need a cutter for foam wings
im needing a cutter to make me a set of foam wings for the meister scale p-47 with the same thickness as a ziroli p-47 wing so i can use sierra precision retracts.... anyone?[]
My Feedback: (15)
WI
RE: need a cutter for foam wings
A couple of questions here...
Do you need them to be a one piece panel elliptical or are you planning on
using built up ailerons and flaps to acheieve that ellipitcal shape?
And also would you be able to provide wing rib airfoil patterns to make templates from?
I cut foam and might be able to help you out.
Tom
Tom
