Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
need a cutter for foam wings
Reply
Old 11-10-2004, 04:06 PM
p-47 razorback pilot
p-47 razorback pilot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default need a cutter for foam wings
im needing a cutter to make me a set of foam wings for the meister scale p-47 with the same thickness as a ziroli p-47 wing so i can use sierra precision retracts.... anyone?[]
p-47 razorback pilot is offline
Old 11-10-2004, 05:01 PM
TOMMYSTA
My Feedback: (15)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: need a cutter for foam wings
A couple of questions here...
Do you need them to be a one piece panel elliptical or are you planning on
using built up ailerons and flaps to acheieve that ellipitcal shape?
And also would you be able to provide wing rib airfoil patterns to make templates from?
I cut foam and might be able to help you out.
Tom
TOMMYSTA is offline
Contact Us Archive Advertising Cookie Policy
