bi wing zagi
bi wing zagi
Has any one ever made a dual wing zagi, and would it fly ? I started with two wings of foam and I wanted to use a speed 400 motor, what do you think. email me = [email protected]
bi wing zagi
I don't own a Zagi but every other guy at my club does. I love those figure eights with the wingtips dragging the runway. Keeeoool.
By all means, try your idea. I would connect the two wings with structural tip plates and some type of vertical fin in the center. Coroplast would probably work. Velcro and tape seems to be the fasteners of choice for the Zagi crowd.
One cool thing you could do is add rudders on the tip plates. Then you could do stall turns. Extra Keeeoool.
bi wing zagi
little bi-plane rule....
keep the wing seperation at least equale to the wing chord. ever seen a twin rudder plane like a shrike wobble the tail end??? not good when it does the same for a set of wings
should I
Keep the top wing before or aft the bottom wing, it looks better aft and I think on landings there is less chance to flip and damage the top wing if it were forward, what do ya think with the CGs and everything to consider?
bi wing zagi
Almost all bi-planes have the top wing forward. The famous Beech stager wing is a notable exception. I would stack them directly in-line. It makes the CG question easier. However, if you do stagger them, just average the CG of each wing. Remember to start nose heavy to be conservative. I would't worry about damage. Zagis are very tough.
bi wing zagi
motor?! ummm ok..
well, if your worried about damaging the EPP nose, i think you better put the motor behind.
be easy enough to launch by holding the top wing
its just a rough idea
Originally posted by phillybaby
that props at the front lol
and you might wanna add a center brace, dont want to see that wing flex now
bi wing zagi
Looks good, now BUILD IT.
Couple more ideas:
Buy two Zagi slope combat gliders.
Add speed 600 power system.
Center and tip panels from coroplast (available from local sign shop).
Put C.G. at average between upper and lower.
Motor and battery could be mounted to center panel ala profile style.
Alternately, you can simply stack two completely stock Zagis. Be careful with the aileron linkage. The flex of a typical epp could cause the upper and lower elevon to get out-of-synch.
Good luck.
Couple more ideas:
Good luck.
zaggi crashed
Originally posted by duanecowgill
[B]This didn't fly... probably nose heavy. [
/B]
/B]
This zaggi I made drove me crazy trying to get the cgs right , it almost flew straight on the last flight then nosed in. see picture=========
bi wing zagi
i think you need the top wing further back, as it pitches forwards the CofG changes too much on the top wing and it just flips nose in... most wing arragements i've seen like this almost have the upper wing as a tail plane to keep it all stable.
need a picture
ep it all stable.
ep it all stable.
Id like a picture if you can fine something that once flew with two wings, thanks
bi wing zagi
lol any biplane. nope, really, i have a mag right next to me with at least two pics of diffrent things exactly what you want, i'll scan it tomorrow when i have time... and if i remember LOL
bi wing zagi
well, i had two planes in my mind, the first was the one on the last page lol, the second i'm looking at now, and is too small to scan. but its like the one on the last page, with a long nose and a pusher engine.
you need pitch stability
