any info on these plans?
FL
im interested in the following plans, wanted to know if anyone has more info on these
1. RCM 1092 by Dennis Tapsfield, the Kari-keen sioux coup
http://www.rcmmagazine.com/e/env/000...=plans:PL-1092
does anyone know that the length of this is?
2. MAN plans - #fsp06971 Mohawk Pinto
http://www.rcstore.com/rs/general/de...6971&catego=PL
does anyone have any info on this? it looks like it would be a fairly easy flier
3. Man plans - Skyfarer #fsp0400a
http://www.rcstore.com/rs/general/de...400a&catego=PL
does anyone know if you could easily add a 2-stroke engine to this, it looks like you could only put a 4 stroke inverted
thanks
thanks
RE: any info on these plans?
I purchased the the following some weeks ago: .
Not a bad set of plans. I hope to start building within a few weeks
I hope to have a os max 4 stroke in her.
FL
i noticed that myself!! i had saved the original article and i almost bought them, but i fly off of rough grass and i was afraid the nose wheel wont take it and i did notice the engine mount, it does appear that the only way to go is with a 4 stroke inverted.
now, you could probably go with a 2 stroke mounted, if you just use the thrust line to go by - but then im afraid you would have to give up the scale nose gear, i thought of doing this way and just using a standard striaght nose gear assembly. unless maybe you get a real long one and bend it out forward??
