Carl Goldberg Sukoi Wing
ON, CANADA
I'm just about to cut a foam wing for a CG Sukoi. I can trace the root rib off the plans and have a damaged tip rib available but not that accuarate. If I take the root rib and reduce it on the computer or photo copier to the length of the tip rib would this work out ok. Or in this particular kit does the airfoil change shape as in some airplanes. Thanks in advance.
Dave
Dave
TX
RE: Carl Goldberg Sukoi Wing
I have built two of these airplanes and I can almost swear that the airfoil is the same root to tip. Of course it becomes smaller, but thats obvious!
Hope this helps,
Tom
Hope this helps,
Tom
