Close a file for plotter print
Hello all,
Can someone here do me a favor and convert my dxf files to plt, using HP Design Jet 750C driver? I think I've spent enough time on TurboCAD LE trying to do this without success. kinkos doesn't have branches in my country. If you can help - please put your mail or send me a message so I can send the files (2 files of an ugly stick). Thanks, Sivan. |
RE: Close a file for plotter print
Not having used TurboCAD but having many years experiance with Acad; you have to plot the DXF from TurboCAD and send it to a file. You have to configure TurboCAD to use the desired driver first. Lately I've been plotting to an EPS file so I can convert it to a PDF in Illustrator.
Should have a whole setup routine to install the driver and set up your sheet for printing. If you want send me your e-mail address via PM and I'll tale a look at your DXF files. |
The H-P Designjet driver is standard equipment on Windows 98 and up installation disks. To create a PLT file, you need to re-install the original Microsoft system disk, then tell your system that you wish to add a printer/plotter and save the plot file. It will ask you to insert the original disk, and automatically look it up for you.
You don't need our help, you may not have realized it was on your system already. Wm. |
