How do cut your balsa?
Hi
I'm new in scratch building, and i want to learn. I was wondering how do you guys cut balsa with the dremel tool, i have the reinforse fiberglass discs but i dont know how to hold the balsa so i wont cut my table.
RE: How do cut your balsa?
The Dremel is good for hogging out balsa blocks, cleaning up holes in things like cowls, making a little clearance in a part, trimming the ends of sticks. What sort of parts are you trying to make? That would help give a better answer.
Use a small scapel like graphic artist knife for most thin sheet parts up to about 1/4 thick. Some longer and stronger knives are then used for general carving. From there use a scroll saw if you want to go with power or a coping saw or small spine backed trimming saw if you don't mind hand sawing. The Dremel is only for hollowing out blocks on the inside.
For cutting out parts you'll want to cut over a sacrifical pad of plywood or similar. Sewing fabric self healing cutting mats work GREAT as they don't dull the tip of the blade.
I want to cut out ribs, rudders, elevator, etc.
I use my hobby knife but takes for ever to finish a part, I'm looking for another way.
TX
I recommend a Riobi 9" band saw with a fine blade. I invested $99 in one about 2 years and it has really paid off. I was at a Home Depot the other day and they're still selling for $99. I also use it for other projects around the house. I used to use an old Dremel Jig saw, but the vibration drove me nuts. The Riobi Band saw is so much smoother.
ORIGINAL: BMatthews
..... and find some patience. Good work takes time and attention.
With a plywood template I can cut out a nice accurate rib with my Xacto knife in about 10 to 15 seconds. If it's taking you longer then there's an issue that can be corrected.
Ribs are easy to make by cutting two patterns out of thin plywood or aluminum. Cut some rough blanks, enough for the number of ribs you need. Drill two 1/4 inch holes fore and aft in the patterns. Use sharpened 1/4" brass tubiing to cut matching holes in the rib blanks. Bolt the stack together, carve and finally sand the ribs down to the patterns. I cut my spar slots with a Zona saw while they are still bolted together. Maybe two hours, including time to make the patterns. Then you can make another set in a few minutes if needed.
The best most accurate tool for cutting bulkheads and other square pieces is a small table saw. Dremel used to make a perfectly workable one. I was sorry to see that go out of production. Micro Mark has one now, but it's pretty spendy. Check with Harbor Freight. I think they have one now that is inexpensive.
Another alternative is a table top belt/disc sander. With a guide, you can make square parts easily. It makes curved parts a breeze, too.
But for sure, get an Olfa cutting mat from a crafts shop, some X-Acto knives, some good straight edges, and a box of 100 single edge razor blades from a paint supply store. Dull blades will make anybody impatient. Not to mention wrecking the quality of the work.
Take your time and learn as you go. Don't be afraid to make parts over to get them better. Cut a little oversize and sand to fit. It's very satisfying to fly something you made entirely on your own.
Thanks for the advice,i don't know why it takes me for ever to cut a simple piece, i guess i need more practice, but i think your tips will make me a better scratch builder.
GA
ORIGINAL: hnfly
For production of straight wing ribs, make a copy of the rib outline and stick it to a scrap of balsa somewhat larger than the outline.
Put the one blank with the outline on a stack of blanks equal to the number of ribs you need. Stick T-pins through the stack to keep the blanks aligned.
Use the belt sander to 'gnaw' the stack of blanks down to the outline and no more.
Use an Xacto or Zona saw to cut out the various slots in the stack all at once.
Separate the stack, and find the glue . . .
