Rotozip
FL
Rotozip
Has anyone tried using a Rotozip with the router attachment for cutting balsa and plywood parts? I think it would work nice for cutting out channels in foam wings for servo wires etc. I am thinking about buying one but would like to get some feedback on it first. Thanks!
RE: Rotozip
http://www.dremel.com/html/home_fr.html
click on attachments, then multipurpose cutting kit. The 565 kit is sold at walmart. If you already have a dremel it's a lot cheaper than buying a rotozip and a lot easier to manage. Just tape down a thin aluminum flatbar for a straightedge and you get a very clean line. I used it on my zagi to cut out the spar notch, and have started doing spars on all my foam planes ever since. Does a very tight servo recess, too. All I do is cover the servo with "zagi" tape or box tape to hold it in on my small birds.
LA
RE: Rotozip
Tools--tools--tools. think that I own a hardware shop and then someone comes up with another new one plus another use for the ones that I have stored away. keep up your uses. dick
