scratch building an edf
VA
Hello everyone, I am trying to build my own edf model from scratch, but I am trying to use only supplies I already have. I am using blue foam board for the wing cores with balsa and ply sheetingfor the wing. I have an old unused alluminum ventilation pipe that is very light and 3" in diameter that I am thinking of using for the part of fusealage. The model is going to be fairly small. This is my first attempt at scratch building so any ideas or comments will be greatly appreciated.
RE: scratch building an edf
My thought is that your concept will not produce sufficent thrust to keep a reasonable sized A/C in the air. Not as simple as putting a fan inside a tube. I am working with Kress Jets at present time on updating one of their older designs. It was a 42-43" span He-162 using the Kress 3 1/3" E.D.F. this whole model is really scrimping for any weight saving feature, including no landing gear. It takes a goodly amount of wing area to support batteries and the E.D.F. unit. I would think to abandon any home design power, and go with a manufactured unit first. Then design your A/C around expected weights.
Wm.
Wm.
Just dig out one of those chintzy postal scales. Plop your radio gear, power, wood, covering etc into a box and weight it, then subtract out the weight of box. It becomes a good estimate as to weight you then need to support, and from that work backwards using wing loading versus wing area formulae. Simple place to begin then.
Wm.
Wm.
