Advanced Sport-3D design questions
Hi there. I would like to design an advanced sport plane, 3D capable. I don't want a radical concept, nor a Extra re-styling either.
My main concern is at the moments numbers, mainly tail. I searched through the forums, but I couldn't find this ratios for a 3D design.
Any information would be of great help.
Thanks and regards.
Thanks and regards.
RE: Advanced Sport-3D design questions
eclipsegsxr,
what about it? do you mean I should take Stik's measurements as a sample to start with?
thks
thks
AK
The easiest (and most precise) way to do this kind of research is to build a simple spreadsheet.
Collect data from publications and actual measurements, of those planes who fly the way you want to fly. Get data on as many planes as you can. As you do this, you'll see the similarities. Then, if you like, you can even average these numbers to come up with moments, etc., that are going to be very close to what you need. As much as I like to think of myself as creative, the fact is that, due to the nature of air and gravity, we are basically redesigning the same planes over and over, with subtle changes.
I would make separate spreadsheets for each "type"... i.e., F3A type, Sport type, 3D type, glider type, etc.. )
