Center of gravity
ON, CANADA
RE: Center of gravity
Make a small 9 or 12 in. balsa model of the same planform. Put a little uptrim in it and balance to get a fast, flat glide. The CG point will be the same for the big one.
My Feedback: (75)
CO
ORIGINAL: Tall Paul
Probably.
Probably.
I would like to know the answer as well, so Tall Paul, are you just out to up your post count[sm=confused.gif][sm=lol.gif]
My Feedback: (75)
CO
I had some kind of CG Calculator, It had something to do with wing cord, span, type of wing and weight, anyway, I believe Kevin did ask the right question
Joe[8D]
Joe[8D]
ORIGINAL: Joe Ortiz
ORIGINAL: Tall Paul
Probably.
Probably.
Without any knowledge of what this configuration could be, there is probably a set of equations which can compute the c.g.
Flypaper's methog works more quickly, than fingering out which parts are wing, fuselage and tail, if the shape is a wierdo.
If the shape reesmbles something already flying, and most do, then what works for the analog will work for this one.
And, the chuck glider is still simpler.
To get into neutral points, static margins, tail volume coefficients, then a LOT more information than "unique" will be needed.
To anwser my own question for those who also wanted to know go to :
http://www.geistware.com/rcmodeling/model_calc.htm
