Sig Fazer (help)
Sig Fazer (help)
hi,
Iv'e built one fazer and my friend two. theres a airfoil generator called profili that you can generate you own tapered wing for the plane.One suggestion that you can do to fazer is to make the rudder longer about 2" that is. Also open up the angle on the elavatorso you get more throw on the rudder.I made this mod. and does great nife edge flight as in knife edge circles my friend even gets knife edge loops out of it.In the profili program you can adjust the how much taper you want.
qfrc flier
qfrc flier
