Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Airfoil for Funtana
Reply
Old 08-24-2005, 02:04 AM
Fikus
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Airfoil for Funtana
Before my question please sorry for my English
I building a 3D airplane Funtana from drawing of Exclusive Modellbau. But i have a problem with wing Airfolils. Which airfoil is used at the end of the Wing? Have you got somebody the original aurfoils from Sebastiano Silvestri? Thank you for all answers. Filip - Czech republic
Fikus is offline
Old 08-24-2005, 12:10 PM
Tall Paul
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Airfoil for Funtana
If memory serves, the tip airfoil is the same thickness as the root airfoil, just shorter in chord.
In a CAD or drawing program, take the root airfoil, and keeping the same thickness inthe y-dimension, change the chord by the percentage difference of the x-dimension between root and tip.
Tall Paul is offline
Old 08-25-2005, 05:39 AM
Fikus
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So that I can use for example NACA 0012 fot the root and NACA 0020 for the top of the wing. I´ve got a built plan prom Exclusive modelbau for funtana 2x2meters and the NACA 64-012A 14% is used at the root of wing. But the airfoil, which is used at the end is not described. I have a lot of photos and the most similar airfoil is EPLLER 476. Can I use a combination of these two Airfoils? Thanks.
Fikus is offline
Old 09-27-2005, 09:15 AM
Stoeptegel
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
Do you have a S or a Pro? In case of a Pro, the root airfoil has not the same thickness as the tip. The tip is 50 mm thick and the root rib is 72,5 mm. This delta thickness, don't know the english word for it, but this difference of thickness is distributed evenly over the ribs from root to tip. In case of a S, I don't know. I only have a Pro.
I just finished mine. Just have to wait for the right weather...
Goodluck with it!
Christiaan Vis
Stoeptegel is offline
Old 10-02-2005, 01:49 AM
PropWrench
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ficus,
Here is a PDF of a wing layout for a scaled Funtana Pro. I also a 2 Meter Exclusiv Modellbau and I reverse engineered it for a .50 size engine. This file has the exact profile used on the 2M bird. Hope this helps.
File Type: pdf
PropWrench is offline
Old 11-01-2005, 08:05 AM
Fikus
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
Thank you for your PDF airfoil. I´m very happy, because this airfoils are the same like my airfoils.
So one more thank you.
Filip, Czech Republic
Fikus is offline
Old 01-06-2006, 04:24 PM
Jerry C
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Does anyone have a file for the wing ribs on a Funtana 140 Pro? I would like to have the ribs laser cut for my scratch build.
Jerry
Jerry C is offline
Old 02-01-2006, 11:53 AM
highfly3D
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi
Dose any one has a plan for 40 -50 size katana, please i need help i searched every were i didnt find one, i want to scratch build it. harrysupley@yahoo.com
Regards
Harry Supley.
highfly3D is offline
Old 03-21-2006, 01:35 PM
GmasterB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
HI All!
@PropWench: Is it possible to get yout 3D drawings of the Funtana?
I'd like to downscale the Funtana to a S90 one (1,4 meters wingspan)
Best regards, Frank
GmasterB is offline
Old 03-21-2006, 10:29 PM
highfly3D
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hello
I am working on a katana 40 size plans wingspan about 55" it will be be ready soon, the ailerons are 1/4" built up like funfly plane but rest all is scale like the actual Katana.
Highfly3D.
Old 04-01-2006, 11:06 PM
Av8er Tim
Av8er Tim's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
PropWrench - What airfoil is used for the Funtana Pro in the PDF? Also, do you have the full plans? I'd like to do a big electric Funtana.
Tim
Quote:
ORIGINAL: PropWrench
Ficus,
Av8er Tim is offline
Reply
Display Modes
