Go Back  RCU Forums > RC Airplanes > Scratch Building, Aircraft Design, 3D/CAD
Reload this Page >
Finding what the CG is on a built model?
Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Old 08-25-2005, 12:41 AM
Ebola0001
Ebola0001's Avatar
Default Finding what the CG is on a built model?
hey guys i was thinking tonight and came up with this
if you used 2 digital scales each at a different point along the planes spine.
wouldn't the cg be the differential between the two?
say one read 5 pounds and one read 4 pounds wouldn't the cg be the proportion of the two shifted from the center between them?
or at 20% of the distance towards the heavier reading from the center of the two points?
see the picture for what i mean
the thought from this came from weighing a car at all 4 wheels at once to determine weight balance.
the thought being that the points the scales were at wouldn't matter as much as their spacing apart and you could find the real cg very accurately
Old 08-25-2005, 12:49 AM
SoCal GliderGuider
Default RE: Finding what the CG is on a built model?
I perfer the finger tip method.
Old 08-25-2005, 10:48 AM
dreadnaut
dreadnaut's Avatar
I use this method all the time myself. I have a scale and two blocks that are the same height as the scale. I place the scale under one wheel, and the blocks under the other two. Repeat three times, and it gives me lateral balance too. I think they use this method on full size.
Old 08-25-2005, 04:35 PM
SoCal GliderGuider
Hang it from a string. Hate math.
Old 08-25-2005, 05:27 PM
dreadnaut
dreadnaut's Avatar
Do the math, I hate the little holes the eye hooks leave in my plane
Old 08-25-2005, 06:47 PM
the-plumber
ORIGINAL: Ebola0001
[link=http://home.mindspring.com/~the-plumber/Vanessa.htm]"Vanessa" [/link]is considerably less expensive than a pair of digital scales and very much faster than calculating percentages. The plumb bob points to the actual CG.
Where it's _supposed to be_ is something else.
