Vacuum bagging help
IN
Vacuum bagging help
I am borrowing my friends vacuum bagging accessories and have wanted to get my own system. He got a used vacuum pump from a hospital. The only place I know is ACP but I hate paying that price when one of you know how to get a setup cheaper. Appreciate suggestions for attaining a system, private emails are fine at [email protected] thanks in advance, Jeff Williams
Vacuum bagging help
I built a very versatile system very cheaply. I had to buy a vacuum switch, a vacuum gauge and a tank. One of those tanks you keep in the trunk for emergency flats. I scrounged an old refrigerator compressor free, a few fittings and some tubing. The whole lot cost me about $70.00.
I purchased the gauge and switch from APC. With the switch is a circuit diagram for the whole system.
I can adjust the vacuum from zero to about 26hg.
Ed s
Ed s
Vacuum bagging help
You can even save a couple of bucks by making the tank from a piece of large diameter PVC drain pipe with a pair of carefully glued on end caps.
IN
Vacuum bagging help
Ollie, thanks for those links. I might try a refrig pump and get the other stuff from ACP. I like the vacuum bagging now that I have done it once. My buddy did the pvc with end caps and a mercury gauge in the middle it works great. Jeff W.
