Retractable Gear
AZ
Retractable Gear
I've been looking for web sites that give information about retractable gear. The information I want is for making a decision on which units would be the best use for a new design jet turbine aircraft.
Information should include dimensions, weight, what size and weight aircraft they are designed for, operational date, etc.
The sites I've checked so far are poorly presented. Does anyone know of web addresses that cover these products thoroughly?
And if you have a particular brand and model you are happy with, what are they?
The plane is about the same size as a Roo or Hot Spot and will weigh about 17 to 19 pounds. Mains and nose need to retract back, nose without rotating.
Maybe the gear manufacturers have this covered in their catalogs.
Retractable Gear
Robart, Spring Air, Unitracts, Likes, and Century all have websites with basic info. Otherwise, you can E mail them with your requirement, they are all usually pretty responsive to queries.
Mike
Mike
