Scratch building -sheeting foam
My Feedback: (131)
I'm very interested in scratch building, so I've decide that sheeting foam would be the easiest way to 1st sculpt, then stregthen with spars and then sheet.
The planes I build will be .40 size, but I'm not sure:
A- What foam I should use?
B- What glue I shuld use to bond the foam?
C- What glue should I use to seet the wings/ surfaces ?
Any suggestions out there ?
MB, CANADA
RE: Scratch building -sheeting foam
A- Use building foam ( Pink is better when cutting w/ hot wire not as much fumes.
B- White wood glue or epoxy
C- Epoxy is better MOP.
I'm almost finish mine. I use news paper to sheet the wings using white wood glue.
roltech
roltech
