airfoil
airfoil
Hi everyone
Anyone got any idead how to convert these scanned airfoil into dxf files or into compufoil files. Any help greatly appreciated
Troy
Troy
RE: airfoil
If you have autocad, then all you need to do is 1) convert the scanned image to bmp 2) in autocad select insert from the menu bar 3) then select ole object 4) select create from file then browse to the image file. 5) open image file 6) trace over image file with a polyline and then save your work as either dwg or dxf.
RE: airfoil
Hi everyone
thanks for the reply and a special thanks to soCal for actually doing it for me. I imorted them into compufoil and it worked perfect
thanks again
troy
thanks again
troy
