Question about enlarging plans.
IN
Merry Christmas to all.
I have a set of plans for a 40 size airplane and I thought maybe I could enlarge them on a blueprint copier at work. Does anyone know approximately what percent I would need to enlarge them too.
Thanks Kev
Thanks Kev
SC
RE: Question about enlarging plans.
It would really help if you would tell us how large you want the enlarged plans to be. And that's easy to figure yourself. Take one existing measurement. The wingspan is a common guideline of plane size, so let's use that. If the existing wingspan is 60", and you want it to be 90", then you divide 60 into 90 and multiply by 100 (for percent), getting 150, which is 150%.
Dr.1
Dr.1
IN
Sorry:
After looking at your reply I realized my question didn't make much sense. I was thinking I could take plans of lets say a 40 size Ultra Sport or Super Sportster and build say a 60 size Ultra Sport or Super Sportster. I wondered how much to enlarge and if they changed anything or just made it larger.
SC
Now that's a question that can be properly answered. When an existing design is scaled up or down, the wood sizes often do not change accordingly. For example, if the original plane had a 1/4" square wing spar, and you enlarge the plans 200%, the new wing spar wouldn't be 1/2" square. If it originally had 1/16" sheeting, the sheeting wouldn't enlarge to 1/8". The best way to figure the wood sizes is to look at an existing similar design and go from there.
Dr.1
Dr.1
IN
Let me see if I've got this right.
40 size wingspan is 55
60 size wingspan is 62
( 62/ 55) * 100 = 112.727272 etc.
Should I round up to 113% or stay with 112 or is it enough to worry about?
Thanks Kev
Thanks Kev
