airfoil choices
airfoil choices
On a lightweight aerobatic 85" wingspan plane can you run two different tail surfaces airfoils? For the horizontal stab I would like to keep the servo mounted in the stab for perfect geometry. Does the rudder have to be the same airfoil or can I run a thinner airfoil? I really hate to run an airfoil as thick as a NACA 0013 for a rudder, but it is what I would like to use as the stab just because I need the thickness. Any better suggestions on what airfoil to use for the tailfeathers?
Steve
Steve
RE: airfoil choices
It should not make any difference at all especially if you stay in the same class of airfoil such as a NACA 0012, 0010 etc. you should be able to go as fat or thin as you like. you can combine as well, such as running a NACA 0014 at the root and going to a NACA 0012 at the tip using a program such as Compufoil to calculate the ribs for you.
RE: airfoil choices
I have used SD8020 for the stab and a NACA airfoil on fin/rudder on my 80" CAP232. The SD8020 is supposed to be less prone to stall with large rudder deflections which means that you will have more effective rudders. The CAP flies well so the airfoils seem to work.
Regards
Hans
Regards
Hans
