Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Jim Pepino's YMF-5 Waco
Reply
Old 10-15-2008, 07:02 AM
  #1276
WacoNut
WacoNut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Jim Pepino's YMF-5 Waco
Good Deal Mike,
I am finishing up the radio installation in my Waco, I have one servo left to install in the wings and I need to install the on/off switch for the engine and the charge jacks. I received the wing tubes for my 33% Waco and man are those things huge I build in my basement and if the plane did not have a removeable stab I am sure it would be too big to get out of the basement.
Later!!
Anthony
WacoNut is offline
Old 10-16-2008, 09:14 AM
  #1277
WacoNut
WacoNut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Guys,
I am getting ready fo rthe AMR 33% Waco YMF-5 build, I am starting a thread in the scale forum, you can follow along here at this link. [link=http://www.rcuniverse.com/forum/m_8053911/anchors_8053911/mpage_1/key_/anchor/tm.htm#8053911]AMR 33% Waco[/link]
Later!!
Anthony
WacoNut is offline
Old 10-23-2008, 08:55 AM
  #1278
hopkimf
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Guys,
Slow but fairly steady progress. Struts done and installed following Big-Bird's drawing. Worked out well. I did end up with some non-identical lengths because I wasn't careful enough locating the brackets on the wings. For the attachment fitting between the wing brackets and struts, I formed a 1/2 in wide strip of brass around a brass tube, flattened and soldered. I didn't pull test it, but it looks like the double thickness of brass strip soldered together should not tear out. For the cabanes, I had previously formed with wire and welded including the diag. braces and feet at the top. When it came to attaching the cabane strut material, I had to bring it to the local machine shop-welder and have a lengthwise slot milled. Also had to nibble at the ends to clear the diagonal brace. Lots of work, but it should look OK once attached. Little end milled slot in strut material ran $40. When I put it all together, I can see why one might go all out and buy a top of the line kit with everything included. Probably money ahead with a complete kit and a lot fewer headaches.
Everything is built with the exception of ailerons. Looks like some work and I'll review the posts to find the best way.
hopkimf is offline
Old 10-23-2008, 12:07 PM
  #1279
Big_Bird
Big_Bird's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good work Mike. Keep it up.
Big_Bird is offline
Old 10-25-2008, 07:42 PM
  #1280
Big_Bird
Big_Bird's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Big_Bird
Due to the fact that the ailerons do not have enough travel the plane rolls very slow. I have just put a lot of differential throw in the ailerons. About twice as much up as down. I'll try this out this coming weekend. The last photos show this throw.
I finally had the chance to fly the Waco today with a lot of aileron differential. The plane rolls at least twice as fast and no longer has the little wobble in a roll. Try it, I'm sure you will like it. I'm now completely satisfied with how it flies and I'm pretty picky. It does a great inverted flat spin and quickly comes out of it as soon as I'm ready.
Big_Bird is offline
Old 10-27-2008, 07:33 AM
  #1281
RICKSTUBBZ
RICKSTUBBZ's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ken,
That is good news about the difference in flight characteristics when adding differnetial aileron travel. How did the engine perform?
RICKSTUBBZ is offline
Old 10-27-2008, 08:39 AM
  #1282
Big_Bird
Big_Bird's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Rick,
I have put 5 more flights on the plane since Bomber Field and I haven't had a bit of trouble with the engine. It is still a little stiff at the end of a flight but that is getting better. I think it is finally breaking in. After Bomber Field I pulled the jug off and cleaned the piston top. No more carbon cat whiskers across the spark plug tip. I don't know if that had anything to do with cleaning the piston.
Big_Bird is offline
Old 10-27-2008, 05:54 PM
  #1283
hopkimf
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
More slow progress. I'm building ailerons now. Last time while building the Ikon Waco UPF-7, I got irritated at the kit design and carved them out of blocks. Not this time. Too big, but kind of a pain to put together. Lots more to do, but it's at the point where I can see a finish not too far off.
ID:	1060151   Click image for larger version
ID:	1060152   Click image for larger version
hopkimf is offline
Old 10-27-2008, 06:31 PM
  #1284
Big_Bird
Big_Bird's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looking good. You sure have put in a lot of work. Fine looking struts.
Big_Bird is offline
Old 10-27-2008, 06:56 PM
  #1285
WacoNut
WacoNut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You will be covering that thing before you know it and when you are all finished you will have something that you can really be proud of. That plane has to be one of the biggest PITA to build that I have ever seen but it makes a beautiful plane when finished.
Anthony
WacoNut is offline
Old 10-27-2008, 07:50 PM
  #1286
Big_Bird
Big_Bird's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
And it flies as good as it looks.
Just took a moment for a break from my airplane factory job. Got to get back before they write me up for taking too long. Working on the top side of the fuselage now.
Big_Bird is offline
Old 10-28-2008, 07:54 AM
  #1287
hopkimf
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Before I can start covering, I have lots of sanding and lots of fixes. Some day I would like to build one that actually looks good without covering. No split pieces, excess glue, wood filler, blobs of JB Weld, etc. Thanks for the comments. It's getting there.
hopkimf is offline
Old 10-30-2008, 06:32 PM
  #1288
hopkimf
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had a little trouble with ailerons. First I built a little fixture to locate the aileron leading edge on the wing in the right position and right angle. Then I trimmed the underside to match the wing taper. Next I laid the bottom sheeting on the board and beveled the bottom edge of aileron leading edge. I glued it on to the bottom sheeting in the flat area. When dry I bent the bottom sheeting up to match the underside taper on the leading edge and glued it in. I put the ribs and diagonals in and sanded all to put the top sheeting on. I was unable to get the bend at the outer end. So I gave up and put in balsa blocks. They run from the last rib, and sit on the bottom sheeting. I don't know how you guys did it. Have more sanding but at least I can get the transition.
hopkimf is offline
Old 10-30-2008, 06:42 PM
  #1289
Big_Bird
Big_Bird's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I found this to work for bending the tips. I think I posted this earlier in the thread but here it is again. It sure makes building the ailerons easier.
Big_Bird is offline
Old 11-02-2008, 01:39 PM
  #1290
Hinckley Bill
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Anyone looking for a rtf Pepino Waco done up in full scale colors and markings let me know as I have one that I'm putting up for sale.
Need to clear space in the hangar for a 1/3rd scale Waco.
Thx,
Bill
Hinckley Bill is offline
Old 11-02-2008, 02:49 PM
  #1291
Big_Bird
Big_Bird's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Bill,
I have no need for it because I have my own but I would like to ask a few questions. Has it been flown? What engine? What does it weigh? How old is it? Did you build it? What are you asking for it?
This almost sounds like Anthony's story. He has a Pepino Waco and is building a 1/3 scale AMR-RC.com Waco YMF-5.
Big_Bird is offline
Old 11-02-2008, 03:23 PM
  #1292
WacoNut
WacoNut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Big_Bird
Almost but I have absolutely no plans to sell either one of my Waco's
Anthony
WacoNut is offline
Old 11-03-2008, 07:10 PM
  #1293
hopkimf
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Guys,
What a surprise. Hinckley Bill sold me the Waco plans plus the cowel, wheel pants and the kit cutter kit. I went to his place some months ago and took a bunch of photos of the plane he's offering now. They're in the thread somewhere. It's very nice. He also has lots of other stuff.
Bill......how about that Harley? How much is that going for?
hopkimf is offline
Old 11-03-2008, 07:48 PM
  #1294
Hinckley Bill
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Plane was purchased from the builder who put a couple of flights on it and then decided to sell it because he couldn't bear the thought of damaging something he'd put so much time and effort into.
I on the other hand got it and immediately replaced all the standard JR servos with Hitec digitals, replaced the "home-brew" copper plumbing muffler with a "real muffler", ran the engine to get it tuned and then put it downstairs to await time to fly.......that time has not come as of yet and I'm not willing to let it sit any longer. I'd like to get $2,000 ... pretty much what I purchased it for plus the replacement of the upgraded Hitec digitals.....but will be open to offers as long as they're reasonable. Sorry to have hijacked the thread like this but I'm subscribed to it and know that others who are also subscribed share my love for the plane.
BTW I just acquired the Genesys Waco and it's sitting next to my Balsa USA Stearman.........they do make a great looking pair.
Oh the Harley isn't for sale at this time.......but here's a pic
Old 11-13-2008, 07:32 PM
  #1295
mango12
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Anthony,
I have been all through here and am having trouble finding what I am looking for.
I know that you used a different method of attatching the top wing to the cabane struts than what the plans called for. Can you refresh me on what that method was?
I was thinking of using monster ball link (6/32 or 8/32) connecters threaded onto the ends of the cabanes, is this what you did,and are you concerned about them coming off under stress?
Scott
mango12 is offline
Old 11-13-2008, 08:10 PM
  #1296
WacoNut
WacoNut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Scott,
I used Monster Ball Links in the front 6-32, this seems to be very strong and I used ends like on the "N" struts on the back. I used the templates supplied by Ken to make the strut connections. I used the aluminum material from GTM to make all the struts including the cabane struts. I inserted the 5/32" wire into the fuse as per the plans but I had it cut short to fit half way up the cabame material and attached it with JB Weld. I put several nicks in the 5/32 wire for the JB Weld to lock onto. The top of the struts were made as described above. It is a must to jib the top wing into place and have it locked in very well while you build the cabanes. I think I measured 50 times before I finally locked it into position and built the struts to fit.
I hope this helps.
Anthony
WacoNut is offline
Old 11-13-2008, 10:33 PM
  #1297
mango12
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Anthony,
Thanks a million!! That is what I will do. I will use the piano wire struts though, and thread them for the 6/32 ball links. I would think this will make incidence adjustments easier if necessary also. I'll let you know how it turns out and provide pictures if I can pry the camera out of my wife's wisely protective hands. Once things get carried into my shop, they never seem to find their way back to the house. Odd, huh?
Scott
mango12 is offline
Old 11-13-2008, 11:16 PM
  #1298
skylarkmk1
skylarkmk1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Scott;
The piano wire is very hard to thread and will damage the threading die. It would be better to silver solder or braze a threaded end to the piano wire.
skylarkmk1 is offline
Old 11-13-2008, 11:30 PM
  #1299
Big_Bird
Big_Bird's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Guys,
Glad to see that this thread is still alive. Every time I think of the effort I had to put in to build this Waco I shudder. Pure determination that it wasn't going to whip me is what it took. It all paid off handsomely with a really fun flying plane.
As opposed to the Waco the AMR 42% Super Decathlon has been a lot of fun to build.
Last weekend was when I had the first thing to break. It was the top right tail brace in the top bend. I never noticed it until I landed. This plane does the absolute best inverted flat spin ever. It gets real flat and comes down slow. Best part is it immediately comes out of the spin as soon as you let go of the sticks. When you get ready to do it just ask and I'll give you the recipe.
Big_Bird is offline
Old 11-13-2008, 11:32 PM
  #1300
Big_Bird
Big_Bird's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I forgot.
Anthony, isn't yours about due for a maiden flight? What's the hold up?
Big_Bird is offline
Reply
Display Modes
