If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 59 of 64 FirstFirst ... 9495758596061 ... LastLast
Results 1,451 to 1,475 of 1578
  1. #1451
    Join Date
    Nov 2002
    Fort Myers, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Jim Pepino's YMF-5 Waco
    Did you guys locate the engine on the center line of the fuselage? I'm replacing the Spehar engine that came with the plane with a DL50 and noticed the builder didn't get it center and was using several washers apparently to center the shaft on the cowl.
    WACO Brother #233
  2. #1452
    Big_Bird's Avatar
    Join Date
    Dec 2001
    Arlington, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I always put about 2 degrees of right thrust in my engine therefore, the engine needs to be moved a little to the left so the prop comes out in the center of the cowl.
    Ken
    WACO Brotherhood #70, Arlington TX home of the Dallas Cowboys, SupBowl45, Texas Rangers, World Series 2010, 2011
  3. #1453
    Join Date
    Nov 2002
    Fort Myers, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ken,
    Thanks, I will put the 2 degrees in.
    Chuck
    WACO Brother #233
  4. #1454
    WacoNut's Avatar
    Join Date
    Jan 2005
    Blanchester, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Chuck I put right thrust in both of my Waco's as well. Like Ken said the engine will sit to the left side of the firewall to center the prop shaft in the cowling. Just make sure to maintain the prop clearance on the cowling. I think I had to make a ply spacer ring for the stand-offs on my DL50 to mount too.
    Later!!
    Anthony
    WACO Brother #30 Cub Brother #17
    It's not the hours you put in It's what you put into the hours.
  5. #1455
    Stickbuilder's Avatar
    Join Date
    Nov 2005
    Leesburg, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: WacoNut
    Later!!
    Anthony
    I don't use right or down thrust. The 27% that is on the drafting table will have none either. There is a left hand stick for something other than the throttle. Use the Rudder.
    Bill, Waco Brother #1
    Its easy, just glue all the pieces together, and sand off everything that doesnt look like an airplane.
  6. #1456
    Join Date
    Nov 2002
    Fort Myers, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Big_bird,
    I'm in the process of hooking up the ailerons and read your post showing the ball links you used for attaching the struts between the ailerons. How are the ball links holding up from the repeated assembly/disassembly? Are they the 4-40 size?
    Chuck
    ORIGINAL: Big_Bird
    Hi Mike,
    I have some suggestions for you based on my experience with my Waco. If you place the aileron interlink points equal distance from the trailing edge of the fuselage you find that the upper aileron will travel farther in both directions than the lower aileron. The first photo shows the upper left aileron and the second photo shows the lower left aileron. What I dis was to reduce the travel of the upper aileron to match the lower aileron.
    Here is a quote of mine from page 52 post #1280:
    quote:
    ORIGINAL: Big_Bird
    ''Due to the fact that the ailerons do not have enough travel the plane rolls very slow. I have just put a lot of differential throw in the ailerons. About twice as much up as down. I'll try this out this coming weekend. The last photos show this throw.
    I finally had the chance to fly the Waco today with a lot of aileron differential. The plane rolls at least twice as fast and no longer has the little wobble in a roll. Try it, I'm sure you will like it. I'm now completely satisfied with how it flies and I'm pretty picky. It does a great inverted flat spin and quickly comes out of it as soon as I'm ready.''
    Mike if you set up differential aileron (more up than down) throw you will find that the Waco will do really nice axial rolls. Of course it takes two different linked channels to do this.
    WACO Brother #233
  7. #1457
    Big_Bird's Avatar
    Join Date
    Dec 2001
    Arlington, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Chuck,
    I'm using the 2-56 ball links and they have held up well.
    Ken
  8. #1458
    Join Date
    Nov 2002
    Fort Myers, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ken,
    Thanks for the reply.
    Chuck
    WACO Brother #233
  9. #1459
    Join Date
    Jun 2003
    Somerville, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    BigBird
    I've been experimenting with this tail wheel set-up with no luck. I've been unable to get it welded or brazed. What type of tubing did you use and what type of weld? Do you do any contract work if you had all the parts cut and fitted. Thanks. Tim
  10. #1460
    Big_Bird's Avatar
    Join Date
    Dec 2001
    Arlington, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: zenith16
    BigBird
    Hi Tim,
    From your description I don't know what you are unable to get welded or brazed or what parts you are using. I used this item from Robart: http://www.robart.com/products/15-sc...ble-tail-wheel as the starting point. I used 4130 alloy steel tubing with a 5/32" ID. You could probably get away with brass tubing. However, you must use high temperature nickel-silver solder with the proper flux and not the low temperature hobby shop silver solder. A propane torch will work for soldering. I don't do any contract work. Good luck.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
    Ken
  11. #1461
    Join Date
    Jun 2003
    Somerville, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ken, Thanks for the ideas. I also have the Robart Tail wheel and saw your finished product somewhere in this thread. I'll get it together somehow. I have a ways to go until the tail wheel touchs ground. Tim
  12. #1462
    Join Date
    Nov 2007
    granbury, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Big Bird I am planning onstarting this project also. I think I saw your WACO at bomber field several years ago and what a plane! You did a great job. I know all the HA's with these plans but I still want to tackle this project. Do you still have the templates for the struts and did ya'll draw the wing tibs more to scale. If you have still have these could you email them to me. Any help would be greatly appreciated. I have a 1/5 NIB PICA kit that I am going to start also.
    Bryan
    Granbury Texas
  13. #1463
    Join Date
    Jun 2003
    Somerville, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ken, I hope you are still looking at this thread. My fuselage is framed and the gear is being installed. My tail wheel came out great and I'm still trying to plan out where all the electronics will go with some access. I was reviewing the thread looking for pictures of the aluminum strut attach fittings that you installed in the wings. All I could find was the fitting drawings for the cabane and wing struts. Did you use the same fittings in the wings. The dual attach fittings look like the angles are different. My only other question is how is your Waco holding up? Is their something you would suggest doing differently? The plans are a challenge but the thread has sure been a help. I think I can have it done by summer. If it comes together, I'd certainly apply for brotherhood. Tim
  14. #1464
    Big_Bird's Avatar
    Join Date
    Dec 2001
    Arlington, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Tim, the Waco has held up very well, I just haven't flown much in the past year. I'm not sure I completely understand your concerns about the wing fittings but here are some photos. I can't recall if I posted them before. If these don't answer your questions then let me know.
ID:	1715856   Click image for larger version.
ID:	1715857   Click image for larger version.
ID:	1715858   Click image for larger version.
ID:	1715859   Click image for larger version.
ID:	1715861   Click image for larger version.
    Ken
  15. #1465
    Join Date
    Aug 2002
    Batavia, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I followed Ken's method (shown above) for the struts and it worked out well. Have not flown much myself. Hope to get with it this spring. Waco is still in basement. It has not flown yet. All I did was fire it up and cruise around yard at home. It wanted to fly.
  16. #1466
    Join Date
    Jun 2003
    Somerville, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ken,. Thanks for putting all those shots on one post. I've fabricated the aluminum ends for the struts. Was there a drawing showing the aluminum fittings that are secured into the wing structures? They do look similar to the strut ends except for the fittings where the guy wires are attached. If this still isn't clear then I'll use the pictures as my guide. Great shots thanks. I'll take a few pictures as things progress. Tim
  17. #1467
    Rainbow1's Avatar
    Join Date
    May 2009
    Shelby, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hello Guys, Does anyone have a set of Pepino's Plans that are willing to part with. I am getting ready to order the Kit Cutters Kit and I need a set of Plans..Please let me know... Thanks
    Robin, AMA #263677, Waco Brother #227
  18. #1468
    Join Date
    Jun 2003
    Somerville, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ken, I wanted to thank a number of contributors to this forum for all their great ideas and tips in building the Pepino Waco. Yourself along with stickbuilder, Damifino and waconut all made this build alot of fun. At this point, I'm sure you are saying this guy is nuts. If it wasn't for the forum the build would not have been the same. It took me about 10 months to complete and I still have to balance, add the aileron connections and clean things up. I'm hoping to fly in early October. The model should weigh in at about 30 pounds. Up front is a Brison 3.2 swinging a 22x8 prop. There is a smoke system installed along with working nav and landing lights that are synched to the throttle. The aileron corrigations were a major issue. After months of searching I could find no supplier for the plastic corrigations that were 1/4 scale. I finally settled on a pattern that gave me a few more ribs but at least the look is there. Don't you know after it's all said and done I find a supplier for the exact scale I wanted. The site is "Park Flyers Plastics" for anyone interested. Since so many great pictures were already posted of your build and others I really just wanted to show some of my finished product. I have not asked for the brotherhood information but plan to after my maiden. This airplane came out great. The forward passenger is removeable and I can mount a camera in it's place. Hopefully getting a video up after a few flights. I really just wanted to add to the forum so that waco modelers might get the bug. Thanks again for all the ideas from you gents. Maybe I'll make it to a Bomber Field meet. Tim
ID:	1802647   Click image for larger version.
ID:	1802648   Click image for larger version.
ID:	1802649   Click image for larger version.
ID:	1802650   Click image for larger version.
ID:	1802652   Click image for larger version.
ID:	1802653   Click image for larger version.
ID:	1802654   Click image for larger version.
  19. #1469
    Join Date
    Jun 2003
    Somerville, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Here is a larger picture of the model
  20. #1470
    WacoNut's Avatar
    Join Date
    Jan 2005
    Blanchester, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Congrats on a beautiful Waco.
    Job well done on a difficult build!!
    Anthony
  21. #1471
    Join Date
    Jun 2003
    Somerville, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Anthony, Just saw you were online. How is your Waco holding up? I've just finished putting together a CG rig and hope to get mine on the mark tomorrow. Fall winds are really blustering in NJ these days but I'm still hopeful for a nice day in acouple of weeks. Tim
  22. #1472
    WacoNut's Avatar
    Join Date
    Jan 2005
    Blanchester, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    My Pepino Waco resides in the Waco Museum in Troy Ohio at the site of the old factory. I donated it back in the spring.
    My 33% Waco went in due to a stupid mistake on landing on my part. I made several errors on landing starting with getting too slow. Took a hard bounce on the runway then tip stalled in. The fuse needs a total rebuild.
    I hope to have my 33% rebuilt and ready for flying by spring.
    Later!!
    Anthony
  23. #1473
    Join Date
    Mar 2011
    Abbotsford, BC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hello:
    I've got a 1/4 scale YMF-5 kit I'm pretty sure that it's the Pepino kit plans. My question here is.
    Does anyone know if the new? DLE 60cc twin cyl engine will fit withou cutting big ugly holes in the cowl?
    I just heard back from AMR and they tell me that the engine is 10 1/4" from spark plug boot to spark plug boot.
    In the picture of the engine the spark plugs look straight across from each other. Wonder if the engine could be rotated so the plug boots get a little extra clearance in the cowl bumps.
    Rick
  24. #1474
    Join Date
    Jun 2003
    Somerville, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RBell, I measured the cowl on my Pepino and it's pretty much 10 1/4" max. The blisters are solid resin so it will take alot of carving to gain very little room. My Brison 3.2 has a side mounted muffler that gives it about 1/4 inch clearance inside the cowl. If you have the mufflers, measure the radius, I would say a maximum of 5 inch radius or 10 inch diameter if your trying to keep everything inside the cowl.
  25. #1475
    Join Date
    Mar 2011
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks Zenith:
    I haven't started building it yet. I have a Fuji 64 that was going to go in a Ziroli F4U Corsair. A Zenoah GT-80 has been purchased for the Corsair. So I was thinking that the Fuji might end up in the YMF-5 Then I discovered the DLE 60cc twin. If it was to fit inside the cowl without having to cut big ugly holes then the Fuji might just get earmarked for some other future project.
    Rick
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
