How to wax a mold with panel lines and rivet details???
I'm looking for some advice. I've got a fiberglassed mold complete with panel lines and rivet details. I'm ready to pull a female off it, but need to wax it up. I know I need to put a bunch of coats of wax on, but how to I keep the panel lines and rivet detail? I don't want the wax to fill these details in. Any advice?
Russ
Russ
My Feedback: (13)
Hi
You really will not lose any detail after waxing as long as you remove the paste from the low spots by buffing carefully.
Use a small stick with a towel at its end to clean th paste out of the panel line. Just buff the rivets.
that is one reason why I exagerate(?) my rivet detail a bit on my plugs, on my glass part, I will have to prime. Don't want to loose all that detail.
Take your time and use care.
good luck
steve
good luck
steve
