Pond racerīs center of gravity
I am making a 59 inch full composite Pond racer for two os 60fx or Webra 60 speed engines, the green spots are servos the receiver an batteries will be in the back center fuselage, the mechanical retracts are gonna be were the legs are. The yellow spot is were i think the cg is gonna be. Do you think the cg is located good, and if it is good enough do you think i could get it to be there just using the weight of the equipment without using led?
