Go Back  RCU Forums > RC Airplanes > Scratch Building, Aircraft Design, 3D/CAD
Reload this Page >
Foam cutter - Duratrax ICE, Solomon SL-30?
Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Old 04-04-2006, 10:59 AM
dbencik
Default Foam cutter - Duratrax ICE, Solomon SL-30?
Hi everybody,
I have seen the foamcutter build by Jim Young in his video presentation and it is realy cool and looks EASY to build.
I have several questions regarding the powersupply for this kind of foamcutter :
1. can I use an NiCd/NiMH pack instead of power supply? I yes what number of cells?
2. I have Duratrax ICE charger - can I use this charger as a powersupply? The charger has an function called DC motor burin-in. Can I use this function to power on the hot-wire?
3. Can I use an ATX PowerSupply for powering hotwire?
4. Can I use Sodlering iron ( Solomon Sl-30 ) with digitaly contorlled temperature ?
I do not want to buy another powersupply just for Foamcutter if any of mentioned posibilities are working. I have seen a thread about using NiMh Pack as a power supply but can't find it.
Thank you for any suggestion.
Old 04-04-2006, 08:56 PM
roltech
Default RE: Foam cutter - Duratrax ICE, Solomon SL-30?
I would not use anything but a regular car battery charger or a ATX power supply if you have but would not use any other thing you mentioned.
roltech
Old 04-04-2006, 09:10 PM
roltech
ORIGINAL: roltech
roltech
Forgot to say that using batteries it could heat up and blow up. this is why other thing you mentioned has some of those traits,
I also heard that you can use a car battery but if it is not controled it can cause serious burns.
roltech
Old 04-04-2006, 09:17 PM
KidEpoxy
KidEpoxy's Avatar
will this do the deed... without casualties?
car batt & ac dimmer (600w inc only writ on back), 12ga from romex for all but the Cutwire ?
Old 04-04-2006, 10:09 PM
roltech
ORIGINAL: KidEpoxy
I don't think so! 600watts dimmer and what ever battery amp. I think it would blow the dimmer. some use a piano wire the "smallest size" and a door bell transformer (cheap) to buy There are links to foam power supply If I come across them I will post the links.
roltech
Old 04-04-2006, 10:15 PM
roltech
ORIGINAL: KidEpoxy
Here is one link to foam cutting plans an power supply.
http://www.utahflyers.org/FCCut.php
roltech
