Need help from you vacuum forming gurus...
ON, CANADA
Ok here is what I want to do:
Create a canopy that is approximately 10 inches wide, 24 inches long and 9 inches high. Is it feasible to do this on my own? I plan on making a home brewed vacuum former. What kind of suction would I need...4HP shopvac? What thickness PETG or acrylic would I need...1/8th? I guess I'm most worried about being able to pull down 9 inches.
Any info is greatly appreciated!
John
John
My Feedback: (60)
AZ
RE: Need help from you vacuum forming gurus...
John, I have pretty limited experience when it comes to forming anything this big but I think you could do it. I have pulled a 16" long Spitfire canopy that is probably 4 or 5 inches deep using a standard wet-dry shop vacuum. If I were you I would probably try running two shop vacs, one in each end of the box, just to have plenty of volume and vacuum. As for material I would think that .06" might be thick enough, or possibly .09" if it is available. I wouldn't think you would need to go up to .125". Just my .02 cents based on my limited experience. Good luck with it!
Banned
John. Micro Mark has a book for 15 dollars that will answer all of the questions that you have not even thought of YET. More than worth the money.
Les
Les
My Feedback: (15)
WI
Wow,
What would you be using to heat the plastic up in?...at your measurements you are going to need a piece of plastic that's a minumum of 36" x 24"....I don't know of any conventional oven available to heat such a piece...plus the frame for the plastic would need to be aroun 8" high to allow for the proper amount of sag as the platic heats...you might be better off to do the canopy in 2 pieces unless you have access to a large oven..I know a commercial pizza oven is fairly large and would be big enough for you...while your there make me a large family deluxe with extra cheese and sausage!!!!!
ON, CANADA
Lol Tommysta! Mmmmm pizza.
Thanks for the suggestions guys. I have a few ideas on how to heat the plastic. I am thinking of creating a heating chamber for it and either using heating coils or actually attaching my heat gun to fill it with very hot air. I am glad it appears to be feasible based on the feedback and I will begin designing everything today.
Cheers,
John
Cheers,
John
