33% Cap 232 Scratch Project
Scratch built Cap 232
96-inch span
3-W 60 for power
Bolly 23X10 prop
Just under 24 lbs.
This is my own project. No plans to speak of. I drew some lines on butcher paper to make sure everything looked about right. The cowl and canopy were from the Hanger 9 33% Cap as well as the landing gear. I matched the cowl colors so that I would be spared the task of painting. The plane flew great. Easy take off and landing. The 3W 60 is a good power plant but just a tad weak for this size plane.
Just thought you might like to see a project completed
96-inch span
3-W 60 for power
Bolly 23X10 prop
Just under 24 lbs.
RE: 33% Cap 232 Scratch Project
Very nice. Any more pics?
I am currently (slowly) working on 80" Cap 232 plans. Power to be 1.40-1.60 glow, with a very light AUW. Dick Hanson used to build 11lb YS140 powered 80" Caps and they flew great. I am just following in his path... I plan to use the Hangar 9 or Midwest cowl and canopy, depending on what is handy at that point. Your 1/3 size is just too big for me to manage for storage and transport, but I bet it flies beautifully.
Mark
Mark
I was trying to follow what Dick Hanson did on a project this size. His came in at 18 lbs. I thought it would be easy to hit that # when I started but I never got there. Mine flies great but I sure would like to see what 18 lbs is like. I guess I wll have to just try again. What ever Dick does he is a master at it. My hats off to him.
ORIGINAL: tonyc
Mark
I built an Edge 540, 80 inch wing Moki 180 for power. It came in just above 14 lbs. It was a D&L Design, I bought the plans but I scratched built to my own taste. Some one else has posted a picture of this same design airplane, D&L, and I think his came in at 12 lbs. So it can be done.
Send me some building pictures if you don't mind sharing. My next project will be a Pitts and this one has to be light.
Tony,
PM me with an e-mail address and I will forward Dick's pics to you. They show a fair amount of detail on the Cap fuse and he used foam core wings. Virtually all balsa, with only a bit of ply around the firewall, too.
Mark
Mark
NY
Hey nice builds!
I see u got Jason Shulman's tail there!
I built an CA 27% Extra 300L as this winters project.
Ive got DA for power, JR Radio, and... also Shulman's tail!!! LOL
THE BEST 3D machine out there!!!!!!!!!! DA is like a rocket!!!
The overall weight came out to 12.5 lbs!!!!
Colombo Andersen really designed some good stuff!!!
Ace
Ace
[quote]ORIGINAL: tonyc
96-inch span
3-W 60 for power
Bolly 23X10 prop
Just under 24 lbs.
tonyc: Is it my immaginagtion or does construction on a project of this size go down more easily than the smaller (let's say a 36' WS or a 48" WS) ones? I've done my share of smaller units and (for me) the larger the plane, the easier it is to build.
Your paint scheme is awesome.
marwen1
96-inch span
3-W 60 for power
Bolly 23X10 prop
Just under 24 lbs.
marwen1
