If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 54 of 68 FirstFirst ... 444525354555664 ... LastLast
Results 1,326 to 1,350 of 1685
  1. #1326
    Join Date
    Aug 2005
    Mississauga, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Scratch building 105
    Here are few more pictures with the update.
    On 2nd cowl i have made all 3 exhaust port openings and sanded the cowl. This took off all the flash and high points. I also dry fitted aft cowl dome to see how upper and lower attachment locations will be on the dome. It still needs bit of work on the attachment locations.
    As for aft cowl dome, i'm thinking to cast those from carbon fiber as i can use them directly to install the motors mounts on the dome with 3/8" plywood backing.
    3rd cowl is also under making at this time, just finished doing second layer to reinforce the cowl.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1754947   Click image for larger version.
ID:	1754948   Click image for larger version.
ID:	1754949   Click image for larger version.
ID:	1754950   Click image for larger version.
    I do believe in KISS (Keep it simple silly), but doesn\'\'t mean my models fall in this category!
    CUB BROTHERHOOD# 173
  2. #1327
    Join Date
    Aug 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    3rd Cowling juss pulled from the mold...
    All 3 cowling together, This one has different color tint to itself, Why i have no clue..
    These reminds me of time when CF-TGE was stored at Polaris trucking company's yard and all 4 cowlings were stacked together vertically just like these......
ID:	1754982   Click image for larger version.
ID:	1754983   Click image for larger version.
ID:	1754984   Click image for larger version.
ID:	1754985   Click image for larger version.
  3. #1328
    iron eagel's Avatar
    Join Date
    Jul 2004
    Middleboro, MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Only one to go, looks good.
    As far as using the domes to mount the motors, I would embed the ply into the layup and I would think that 1/8 inch ply should be all you need as it will be backing up composite structure.
  4. #1329
    Join Date
    Aug 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: iron eagel
    Good suggestion Paul, I'm not so sure about 1/8" Ply but i would minimum would go 1/4" just to have peace of mind plus, i will add 2nd layer copulating the wooden piece between both layers. This way it will be super strong and will take all the that it will get from the motor. I would be using blind nuts to tighten there mounting screws or stand off if i could find them for the length i will need.
    As for the cowls, yeah 1 more needed for the model but i'm going to make 3 more!, two to keep as spare and 1 will be going to my buddy Frank who helped me with making these awesome molds....
  5. #1330
    iron eagel's Avatar
    Join Date
    Jul 2004
    Middleboro, MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Keep in mind with an electric motor you don't have the vibration of an IC engine to deal with so the supporting structure does not need to be as robust. Now is about the time to start checking things like the weight and balance making sure your COG is going to be close.
    In the final stages of the build I like to really keep and eye on where that is headed...
    Granted with the small stuff it is far more critical, but still any weight you have to add to get your CG right is baggage.
  6. #1331
    invertmast's Avatar
    Join Date
    Dec 2003
    North Port, Fl
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    If you do the nose bowls in carbon and use them as a firewall, 1/8" ply firewall will be plenty strong enough
    Thomas W.
    Scratch built: 1/7 F-14D Tomcat, 1/4 TA152H, 1/6 EA6B Prowler up next?
  7. #1332
    Join Date
    Aug 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    [youtube]http://www.youtube.com/watch?v=BlTOT-Ip_VU&feature=colike[/youtube]
  8. #1333
    Join Date
    Aug 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well i just finish doing layup of 4th cowl, i was hoping to do it faster then others but it still took couple hrs fro the while process. Tomorrow i will.start making molds of the dome/bowl piece and lower intake scoop.
  9. #1334
    Join Date
    Aug 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Finally juss pulled 4th Cowl from the mold, ud imagine by nowthese would juss pop out, Na dont kid urself,.this one was most stubbun coming out of the mold. Later on today i will assemble whole model with all 4 cowls on it and do a photo shoot of it.
ID:	1756344   Click image for larger version.
ID:	1756345   Click image for larger version.
  10. #1335
    Join Date
    Aug 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well here i dry attached all 4 engine cowlings on the Constellation. Can't wait to make the mold of the aft dome piece so i can actually mount these on the nacelles permanently.
    Presently i'm making the mounting surfaces on the dome piece plug, there dosen't seems to be much attachment area on the upper mounting surface for main cowls to solidly attach on the dome.
    I'm going to see if i could block the air passage at the mounting location and use that to secure cowl on the dome section. Lately i've been thinking on making these cowls open in scale fashion for display and motor and esc maintenance but lets see if
    i could go that far.
ID:	1757309   Click image for larger version.
ID:	1757310   Click image for larger version.
  11. #1336
    Join Date
    Aug 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Main air intake opened up on #2 engine cowling, i also opened up cut outs for all 3 exhaust opening on both sides cowl flap doors.
    This cowl was also sanded smooth, took off all the flash and joint lines from the molding process. All this one needs is use of auto bondo filler to fill all the low spots on the cowling before it's primered..
ID:	1758020   Click image for larger version.
ID:	1758021   Click image for larger version.
  12. #1337
    Join Date
    Aug 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Cowl's aft dome piece is almost ready for molding process. All three exhaust outlet contours needed to be made more crisper and sized properly according to port cut out on the main cowling. I am going to put light layer of fiberglass to seal all the filler work just done on it plus also to keep it crisp. Then i'll use flite metal to make the side panelling on this dome piece and add some rivet and panel lines detail. After this dome plug will be ready for mold release....
  13. #1338
    Join Date
    Aug 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Also preparing lower air scoop for fibre glassing before i cut it into pieces to make the molds of it. It's going to be in 2-3 pieces so all undercuts are avoided.
  14. #1339
    Join Date
    Aug 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Cowling aft dome plug...
    Plus a over head shot of CF-TGE when it was used as a restaurant back in mid to late 90's n into early 2000's...
ID:	1759352   Click image for larger version.
ID:	1759353   Click image for larger version.
    Attached Images Attached Images
  15. #1340
    Join Date
    Aug 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    This motor mount's footprint on 1/8" ply will be cut off the sheet and will be glued on the dome at the centre of it. This will help in making cast parts with this indentation inclusive once this mold is made.
    EDIT: 10 mins later foot print ply piece is cut, edges sanded and placed on the face of the dome piece.
ID:	1759357   Click image for larger version.
ID:	1759358   Click image for larger version.
  16. #1341
    Join Date
    Aug 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ok, iwas waiting and hoping to get some feedback before i commence on fiberglassing this plug n then making its mold. since No one has said anything, im going ahead with my plans.
  17. #1342
    Join Date
    Aug 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Motor, mount, mounting plate and aft cowl dome plus dry assembled together to see how they will the mounted and also to see the clearances.
ID:	1759457   Click image for larger version.
ID:	1759458   Click image for larger version.
  18. #1343
    Join Date
    Aug 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Now with cowling on but with and without prop mounting collet piece.
    It would have been nicer if i had the propellers on me at this time, that would have been perfect test fit of everything together.
ID:	1759460   Click image for larger version.
ID:	1759461   Click image for larger version.
ID:	1759462   Click image for larger version.
ID:	1759463   Click image for larger version.
  19. #1344
    iron eagel's Avatar
    Join Date
    Jul 2004
    Middleboro, MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The domes look good Sam, I really like the look of the cowls with the exhaust cutouts as well.
    Only one thing the motors look like there sticking out a bit to far, you will know better when you get the prop adapters in place.
    Are you going to use a dummy radial cover for the motors?
  20. #1345
    Join Date
    Aug 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks Paul,
    Yeah this is just a dry assembly test i did just to see how things will be once CF domes are made. Off course proper spacing will be done later on.
    No i will not be using dummy radial engines as there will be another round 1/2 doughnut shape pieces that will go between the spinner's backing plate and into the air intake!. This is one of those odd things that only certain types of aircrafts had and S Connies had them with Curtis Wright 3350 engines...
ID:	1759626   Click image for larger version.
  21. #1346
    Join Date
    Aug 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Here are few more pics with old APC 2 Blade 12x6 prop i found in my stash of stuff.
    It sure looks tad further then where it should be but with this 1/2 doughnut piece, i think it will make it look where it should be in the end.
    I'll see if i should engrave this ply piece 1/16" into the dome's face plate structure, this way gap will be 1/16" reduced in prop/cowl spacing.
ID:	1759638   Click image for larger version.
ID:	1759639   Click image for larger version.
ID:	1759640   Click image for larger version.
  22. #1347
    Join Date
    Aug 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Paul,
    Here you go, i just removed the ply plate and reduced gap spacing by 1/8" between prop n intake lip...
ID:	1759679   Click image for larger version.
  23. #1348
    Join Date
    Aug 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Paul,
ID:	1759681   Click image for larger version.
  24. #1349
    iron eagel's Avatar
    Join Date
    Jul 2004
    Middleboro, MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Oh yea, I forgot about those center faring in the cowl, no need for dummy radials here!
    Rather than yank out the plywood I would look at shorting up the mount a bit.
    I have used these mounts in the past myself and had to "modify" them so I could get the motor tho sit where I wanted it to. There is some cutting and drilling required I know, it's just that the mounts come as one size fits all and in the real world that never seems to work. Besides I like to keep all the spinning mass of the motor closer to the firewall, it puts a lot less stress on the entire assembly, as opposed to having the motor cantilevered out from the firewall. One another note I have mounted the motor internally to the mount as well using the spinning shaft that sticks out he back for the prop mount. Now in that case the wires were visible but with your center fairings that shouldn't be a problem to bury them.
  25. #1350
    Join Date
    Aug 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Lower air scoop!!
    Well every time i say to myself, it's done and ready for final layer of glassing, i look at it from another angle and there is more to do on it before i can say it's done ready for glassing. I had to add extension at the rear end of the fairing to get nice even uniform blend of this on the nacelles and main gear doors. Then came filling and sanding, filling and sanding steps over n over!. Well hopefully after sanding this last section, it's ready for final layer of fiberglass and then making molds of it...
ID:	1759897   Click image for larger version.
ID:	1759898   Click image for larger version.
ID:	1759899   Click image for larger version.
ID:	1759900   Click image for larger version.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
