If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 57 of 68 FirstFirst ... 747555657585967 ... LastLast
Results 1,401 to 1,425 of 1685
  1. #1401
    Join Date
    Sep 2002
    Jupiter , FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Scratch building 105
    Sam,
    WOW! Have you made headway with that model!!
    I haven't been on RCU for a bit and I gotta tell ya, your model is really shaping up.
    Kudos and good going!!
    Charles
    Owner: CFC Graphics. "Model Airplane Graphics from a Model Airplane Builder." cfcgraphics.com
  2. #1402
    Join Date
    Aug 2005
    Mississauga, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Avaiojet
    Sam,
    Charles
    Hey Charles,
    Good to see you on here again and thanks for liking my progress and encouragement....
    Here is what i am presently working one, basically splitting time between 2 major projects now that Connie is right around the corner from completion...
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1767230   Click image for larger version.
ID:	1767231   Click image for larger version.
ID:	1767232   Click image for larger version.
ID:	1767233   Click image for larger version.
    I do believe in KISS (Keep it simple silly), but doesn\'\'t mean my models fall in this category!
    CUB BROTHERHOOD# 173
  3. #1403
    Join Date
    Aug 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Got my Carbon fibre cloth today, so ill be making dome pieces .starting tonite. I will also make one.remaining. lower
    air intake scoop also. My MS 12x8 3blade props are on the way so i will now able to make atleast one full
    cowling in this week hopefully.
  4. #1404
    Join Date
    Aug 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I didn't realized up till last night that i was out of working gloves til i set everything up and found that out, good that i didn't mixed the resin as it would have been wasted. Carbon i got is 5.8oz sq/in, so this should be more then enough to withstand any vibration, torque Rimfire 55 motors has to give plus would be very advocate to mount motors on it directly but i'll copulate plywood square to act as flat surface for motor mounts to be mounted on these domes...
  5. #1405
    Join Date
    Aug 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well here it is, first ever Carbon fibre dome piece made for this model!, 1 down 3 more to go.
    I also made last lower scoop from Carbon Fibre, lets see if i could do the same for front section due to small, tight and complex mold...
    This is first time ever i'm working with carbon, i like working with it but only problem i faced, cloths strands would move apart and make gaps in the cloth surface, this time i added small pieces to cover the gaps and also used lighter weight fibreglass cloth also to fill open gap areas. I would like someone on here who does work with carbon to advise me what i'm doing wrong in lay up procedure why strands tend to move apart on the wall's surface.
ID:	1767770   Click image for larger version.
ID:	1767771   Click image for larger version.
  6. #1406
    Join Date
    Jul 2002
    Sterling Heights, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Sam,
    My experience with CF cloth is that it does not take on small curves well. Tends to want to straighten itself out during curing. As for the strands seperating, the strands (called tow) are more loosly woven than glass cloth plus they are made out of thousands of fine filiments for each piece of tow. Possiby two layers of 2 oz CF cloth would have been a better choice.
    Frankly, I don't mold anything from CF cloth that is small in size and has small curves because it requires constant attention untill the epoxy cures. It's a PITA!
    This is my persnal opinion and others may have a different one.
    George
  7. #1407
    Join Date
    Aug 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Here are the parts pulled from the molds. I tell ya, pulling the dome piece wasn't easy task to do....but i got it out without damaging the mold. You will see, wet resin around the square section, i didn't thought to put bigger piece in the dome after layup to prevent big air gaps, but nit going to waste this piece, so i mixed bit of resin n applied it to those areas...hopefully this will do the trick...
ID:	1767933   Click image for larger version.
  8. #1408
    Join Date
    Aug 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    George, im running late for my company's seminar, ill get baick to u later tonite....
  9. #1409
    iron eagel's Avatar
    Join Date
    Jul 2004
    Middleboro, MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Sam,
    I agree with Ampbomber Your using far heavier fabric than you need. I would think that using the two layers of the 2 oz fabric would be more than adequate. Keep in mind the carbon fiber is much stronger than the fiberglass to start with so you need a lot less.
    As far as results you got working with carbon fiber cloth they are similar to what I have seen and not a lot to be alarmed about. It doesn't like to lay over curves well ,and because of the weave, it tends to separate along the edges much like you have seen even when not going over small radius curves. I think for the most part carbon fiber is used in conjunction with vacuum bagging when making up components with it. I of course have not tried that yet, but am thinking about it for a build I would like to do in the future. It's my understanding you can get a lot lighter weight out of the parts when you make up parts that way.
    I would still recommend you check with the guy's in the composite forum, they could give you far better info than I could. I have to wonder if six or seven layers .2oz/ of omnidirectional carbon fiber veil (tissue) wouldn't work well fpr what you are doing.
  10. #1410
    Join Date
    Aug 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I do agree with you George, it should be made with 2oz cloth but to get that much i'm talking well over $100 per/sq yard!, i got hell of a deal on lots of 5.8 oz CF cloth so i bought this instead. Tows do tend to shift but i didn't had problem with getting it into tight spots or curves at all, it's not different then working with FG cloth. Plus these part prolly weight less then paper even!.
    I'll try coulpe different tricks to see what works best for me and use that for the rest of CF use...
  11. #1411
    Join Date
    Aug 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Flash has been trimmed off from the back of the dome, dome has been dry fitted on the back of the main cowl piece, lower scoop is also dry assembled. Now you guys can see how full complete cowlings will look once all 4 are completed!....
ID:	1768048   Click image for larger version.
ID:	1768049   Click image for larger version.
ID:	1768050   Click image for larger version.
ID:	1768051   Click image for larger version.
  12. #1412
    Join Date
    Aug 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    As i'm getting closer to finishing my S Constellation model, i have been recommended by few guys to hook up 2 left motors in opposite turning direction from right side!,. Meaning if one side it turning clockwise then opposite will turn anti-clock wise, plus props one side will be puller but otherside will use pusher props....
    Does this makes sense as on actual Connies, all 4 engines turn in one direction...
    http://www.youtube.com/watch?feature...&v=v3MBmS3APP0
  13. #1413
    Join Date
    Dec 2009
    , QC,
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I like you planes much pls stop tell complain on me.
  14. #1414
    invertmast's Avatar
    Join Date
    Dec 2003
    North Port, Fl
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    counter rotating props will just cancel out much of the Torque and P-factor tendencies. They typically didn't use this technique much on Full-scale aircraft b/c it involves having to have different engine/prop combo's for each side of the airframe which = more money, especially if its just one aircraft that uses that particular prop/engine combo
    Thomas W.
    Scratch built: 1/7 F-14D Tomcat, 1/4 TA152H, 1/6 EA6B Prowler up next?
  15. #1415
    Join Date
    Aug 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hey Thomas,
    You are right and i have already got this straighten out on another forum by guys flying 4 engine models. P-Factor and torque will not effect on planes with wing mounted engines specially with 4 engines as torque acts around the center line of the motor/s. Airplanes roll along the centerline of the fuselage. What is commonly called "torque" is actually P-factor, which only has an effect at high power settings, high angles of attack and low airspeed. And that's easily controlled.
  16. #1416
    Join Date
    Aug 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Sorry guys no build updates, work has been really busy and so as last weekend but i wanted to see how big wings are on my Concorde in comparison to the S Connie, i like what i saw, to thought you guys will also...
ID:	1769299   Click image for larger version.
ID:	1769300   Click image for larger version.
  17. #1417
    Join Date
    Aug 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have ordered Turnigy Plush 60 Esc's, EC5 connectors, wiring and Turnigy electric 3 blade 15x8 props for this model. This stuff should be here in next couple of weeks, i already bought 2x 5000 mah 6S 40C lips for this baby...
  18. #1418
    Join Date
    Aug 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Front section of the lower intake scoop is being made now. This is first front section that has been reinforced in the mold while lay up process with carbon fibre.
    Scoop's main body's edges and corners are also being fixed with the resin, also low spots were filled with light layer of resin.
ID:	1769694   Click image for larger version.
ID:	1769695   Click image for larger version.
ID:	1769696   Click image for larger version.
  19. #1419
    Join Date
    Aug 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Carbon scoop dry assembled and dry fit on Nacelle #4. Intake lip's body is perfectly fine, it's combo of fibreglass reinforced with CF, there are "0" air bubbles on it...
ID:	1769773   Click image for larger version.
ID:	1769774   Click image for larger version.
  20. #1420
    Join Date
    Aug 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Today happened to be a day when S Constellation was taken out for the first time under clear blue sky to get some sun...
    Also today was first time in 6 years of this build that she stood on her own landing gears!, plus had all 4 cowlings on her nacelles....
ID:	1770389   Click image for larger version.
ID:	1770390   Click image for larger version.
  21. #1421
    Join Date
    Aug 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Cowl reinforcement process started..
    First of 4 cowlings went back the mold to get carbon fibre reinforcement done to areas of "Cowl flap doors", btw these doors will be operational!
    Making #2 Carbon fibre lower air intake scoop.
ID:	1770425   Click image for larger version.
ID:	1770426   Click image for larger version.
  22. #1422
    Join Date
    Dec 2001
    Litchfield Park, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Props4ever
    Very impressive Props. Nothing is more elegant than a Connie IMHO.
  23. #1423
    Join Date
    Aug 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Chad Veich
    Thanks Chad. I'm happy with the out come so far...
    Second cowl has been reinforced also, peal ply was applied to soak up all the access resin from the layup.
    Before i applied resin and Cf, i sanded inside lightly with 100 grit sand paper for good adhesion!, first one was not sanded, so it's ok but not as good as this should be....
ID:	1770642   Click image for larger version.
  24. #1424
    Join Date
    Aug 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Reinforcement process completed for 2 cowlings, #3 and #4.
    Cowling 4 will need more resin applied to it's surface as there are air gaps between the carbon and fibreglass, this happened due lack of sanding that should have been done before carbon was applied, you live and learn!...
ID:	1770676   Click image for larger version.
ID:	1770677   Click image for larger version.
  25. #1425
    iron eagel's Avatar
    Join Date
    Jul 2004
    Middleboro, MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Gee Sam I would have thought that the fiberglass would have been strong enough on it's own, now I'd say it's pretty much bullet proof.
    Looking good!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
