200% size slow poke
RE: 200% size slow poke
More progress on the wing tonight!
I cut and glued the mounting plates for the gear and the the wing pin tonight, the wing wing center section is approching 3lbs. The weight is mainly from the hardware and plywood for the gear and wing joiners. The landing gear will be 1/4" wire.
Take care all!
Take care all!
Take care all!
Take care all!
ORIGINAL: BMatthews
What are you going to cover this with? I want to call my broker and buy stocks in the company making the stuff before you go out to buy.....
Coming along nicely.
Take care!
Crazy
#35
My Feedback: (64)
MS
looking good, i like your pvc clamps. i am building a double scale greatplanes oldtimer at this time. i will try to get my wife to post some pics for me. good day . (BUTCH )
#36
UPDATE TIME FRIENDS!
Sorry for the long delays in the posting process fellow slow pokers! I am finally back on the project and rounding the corner to the home strech. The wing is almost complete and notched into the fuse. Here are some pics of the progress.
#38
ORIGINAL: BMatthews
I have to say that she looks impressive. And I see that cancelling your internet account wasn't enough to pay for the covering material yet.....
#39
ORIGINAL: vicarh
Crazy,
Did you give up on the Slow Poke project?
Also, I like the PVC pipe clamps (I think!) could you please post close up photo...?
Crazy,
The pvc clamps are cake.
Slice two inch pvc to 2.5" lengths
slice into the 2.5" with a band saw or hack saw
with the slice at six o clock, drill a 3/16" hole at 2 and 10 o clock
stick two screw drivers in the holes to open and sqeeze away!
#42
OK friends. All controls are hooked up and working, Here are the last pics you will see before final sand and covering. I did not mount the engine because I am still not sure if I am going to go with a 100cc twin for balance issues. I did not screw in the outer wing panels so they are not tight in place. They are tight and smooth when fastened. Next step is to fill, sand, fill, sand, fit and monokote. I will post pics of that
Thanks all
Thanks all
#43
NY
nice project you have there..you picked the right one, looks great...if you leave it togeather and just strap it to the mini van, you could do touch and goes on the way to the field...if you look back 80 years bernie pietenpo used cotton sheets to cover his first homebuit..and that was before king size beds
your never lost in a cloulds, just site seeing
#44
ORIGINAL: m011biker
Thanks to everyone for the posts!
#45
NY
a friend of mine built one , up to the covvering stage, then sold it for 42 hundred with 2 run out cont engines..thinkin you could have saved over half he rib weight on the SP if done the same as the full scale piet...
#47
ORIGINAL: Murdoc
That looks awesome If I dare to ask you.. how much have you spent on this baby?
Less than 500 out of pocket not counting labor of course
#48
Here are some pics of my progress. I installed LED lights in the wing for added fun.
The LEDs can go solid or flash.
Thanks ALL
Thanks ALL
