Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
how to reallign my planes tail
Reply
Old 09-19-2006, 12:20 PM
diego007
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default how to reallign my planes tail
I had have a crash and my planes tail broke off. but my problem is how to get back my horizontal stabilizer in line with my wing.
ID:	526900   Click image for larger version
diego007 is offline
Old 09-19-2006, 12:23 PM
diego007
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: how to reallign my planes tail
more pics
ID:	526905   Click image for larger version
ID:	526906   Click image for larger version
diego007 is offline
Old 09-19-2006, 12:27 PM
diego007
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
and more...
ID:	526910   Click image for larger version
ID:	526911   Click image for larger version
diego007 is offline
Old 09-19-2006, 07:04 PM
aerowoof
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I mount the wing first and on a large flat sorface i make sure from tip to surface on both sides measure the same.then I glue on the stab making sure tip to surface is the same and from wing tip to stab tip is the same and from centerline at firwall to each stab tip is the same.after the glue dries I glue on the rudder using a triangle to keep it 90 degress to the stab and straight on the centerline
aerowoof is offline
Old 09-19-2006, 11:11 PM
Rcpilot
My Feedback: (78)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It's a trainer. Doesn't have to be exact to make it fly.
Where is the tail? Can you strip the covering off and slide it right back into place? That should be close enough. The broken wood should go back together like a puzzle. Should fit back almost perfect. Just slide it back in there and check the fit. Then pull it out and put some epoxy in there. Slide it back in and clamp it untill the epoxy dries.
Rcpilot is offline
Old 09-22-2006, 02:50 PM
rahtware
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Rcpilet
Yes a trainer is more forgiving, and can be set up less than perfect, but it is always better to have things lined up (as per the original design) as well as you can.
rahtware is offline
