Window repair/replacing
My Feedback: (175)
IL
Cracked up my Hangar 9 Taylorcraft and broke the front window. Can someone tell me how to make a clean repair or how to make a new window? It is contoured so Im not sure what to do.
RE: Window repair/replacing
Remove the window.
Tape it down to some K&S clear acetate/plastic (or similar material).
Trace the outline onto the clear material (a Pilot "Razor Point" pen works well for this ) OR trace the outline onto a piece of paper and tape the paper to the acetate/plastic.
CAREFULLY remove the original windshield as the pen markings will smear. With a paper template I would leave it in place and cut around it.
Use a #11 blade and cut the windshield out.
320 - 400 grit paper used CAREFULLY will smooth any rough/jagged edges.
I would suggest using .015 or .020 thickness plastic material.
It really looks like a replacement could be made from a flexible sheet. While it's bent more than one way, it really loks like any area only has a single curvature.
Trace the outline of the original, make one out of some light card stock and see if you can make the bends. It may not be exact but it might be enough to suffice. If you make it fit, get some flexible clear stock and use the card stock for a template.
Dave
Dave
