Remove or leave the line of the pattern when cutting out ribs,formers,etc ?
My Feedback: (13)
FL
Kinda new at making parts from plans. Am I being too critical being concerned about whether to cut to the line, remove the line or cut to middle. No problem on some plans as lines are very narrow. Some are not,especially if plan has been enlarged. Maybe plans vary and I need to ues a set of dividers and check outline of parts to their use in other sections of plans. Any help will be appreciated.
KG4MIN
KG4MIN
ON, CANADA
I usually cut to the line with a bandsaw then finish sand with a sanding block. Usually ends up in the middle.
It's easier to remove than add. When I'm in doubt it stays a little proud of the line and gets trimmed during the preglueing "analysis".
Sometimes this is a no brainer. I only ever got caught once cutting a set of elliptical ribs to plan only to find that they were as much as 1/16 short in a few cases. Now I'd leave them all an 1/8 to 3/16 long and trim during assembly. Same with the thickness at the trailing edge. It's easy to slightly sand the ribs down but it's a long haul to sand the whole trailing edge down. So the ribs get left long and fat for the last inch unless I'm doing a stack sanded rib block and I can compare the stock to the block.
I hate surprises....
lines
It doesnt matter how you do it. Just remember that once you do it one way either leaving the line or sanding it off do the same on all parts and they will all be the same.
I like to cut just shy of the line and sand until it just disappears. Plans are never perfect due to weather can cause the paper to shrink expand whatever. but if you stick with the same method of cutting out and sanding your parts they will all be only as good as the plans were no matter how good you are at cutting them all the same you will always have to touch them up when building.
Joe
Joe
Now B Matthuse shows he done a bunch a balsa butchering. I leave the line and even a bit more depending on where the part has to go. Plans are not created equal some distortion can exist from plan to plan and weather it was copied , printed or hand inked.
I have even cut parts from plans that were not close to fitting. So leave the line and a little more.
Don't ya just hate having a pretty box of parts that don't fit.
When I design a rib I make sure that if there is to be any sanding done it will be the rib, not the spar or trailing edge.
Also I leave the ribs 1/8 long because some guys like to notch into the trailing edge. Sure enough, I get some *****ing because they had to trim the length. How sad!
Plans can have some distortion due to the copy process or the weather so you have to do some "fudging" occasionally. Best to have the parts a bit "proud" as was suggested...
