Large foam blocks
Large foam blocks
Where can i get large quality foam blocks to cut via hotwire? I'm in need of somethin' around 18" x 18" x 10" minimum... suggestions?
:drowning:
scuba
:drowning:
scuba
Large foam blocks
roofing/insulation suppliers can supply various foam sizes. Not sure if you'll find the exact size you need.
Also check your favorite home improvement warehouse.
I've used 3m77 to glue blocks together before hotwiring. You could try that if you cannot find the size or thickness you require.
My Feedback: (14)
Large foam blocks
Depending on where you live, you may be able to find some from people who build boat docks. I had a block someone gave me that was at least 2'x2'x4'. The guy said that's where he got it from....
