painting
OK
painting
hi all,
i'm building a sig tri-star from plans ( the kit is long gone ) and i'm going to paint instead of using film.
can y'all point me to a good FAQ, How-To, or other resource where i can learn about painting?
thanks
frank
thanks
frank
ON, CANADA
1 Post
RE: painting
Hi Frank,
It would be good starting point if you can post a picture that you want to replicate on you model, this way guys can see it and can guide you how to do lay one color on top or paint one coloor with other, i am sure you have painted before and you know how to mask and cover areas up, if not then RC model is not the best way to learn how to paint.[]
OK
RE: painting
ah... there's the rub.
I haven't painted balsa models before. I always used heat shrink film. This time i want to paint.
i know about painting wood in a general sense... fillers, sanding 'tween coats, etc. I have some experience with airbrushes, and using frisket to mask, etc.
all i think i need is a bit of advice on fuel proof primers and finish paints, etc. And any techniques that are necessary for a good result, but not immediately obvious to the novice painter.
thanks
frank
thanks
frank
My Feedback: (14)
ID
RE: painting
I am doing a painting project for the first time too.
I know if you want a smooth surface, you can use 2 modest coats of polyester resin, such as Sig finishing resin. You can sand between coats, but make sure you sand thoroughly before painting. Remember that 90% of the finish's appearance is a direct reflection of the surface prep. I learned this painting cars.
I don't think you need primer if painting resin-treated wood, but I am new to this as well. I could be wrong.
As far as paint, I am looking for advice myself, so I am no help here. I would opt for using an airbrush over a spray can. More control and more consistent droplet size of the paint
Anyway, good luck.
Stu
Anyway, good luck.
Stu
RE: painting
ORIGINAL: stupidaso
Anyway, good luck.
Stu
Anyway, good luck.
Stu
Bill, AMA 4720
WACO Brotherhood #1
RE: painting
rocannon,
Check the Warbirds or Scale sections here on RCU or on RC Scale Builder http://www.rcscalebuilder.com/forum/default.asp . There is a thread on finishing in the General section of RCSB. If anybody knows how to paint it is the Scale guys. You will need to cover any open areas with Tissue, Fabric or film (Film can be painted), then fill the weave and/or grain of the structure with some sort of primer. I use to use clear dope (Aero Gloss) way back when with talcum powder to fill the grain, sanding between coats, then applied the color lightly and finish with a light coat of clear. For your first paint job, keep it simple with the materials. Latex is cheap, cleans up with water , has low oder and can be mixed to custom colors at places like Wal-Mart, Lowes, Home Depot and other places, but is not fuel proof and needs a coat of clear polyurathane to fuel proof.
RE: painting
Latex needs to "cure" before you clear coat it.
Flat latex takes about 10 days to cure, semi-gloss and gloss can take as long as 3 weeks.
To see if the latex is cured, press your finger firmly on a hard spot (I use the cowl area ). If a fingerprint remains, it is not cured. (Don't worry about the fingerprint, it will disappear in a day or two )
For clear coats, do a search under Campy in the tips and tecniques forum. I have done some testing on alternatives to Lustercrap and Ultracote clear for fuel proofing.
