plan elarging help please?
hi i have a set of plans that i downloaded they are in tif format.now i want to get them enlarged to there origional size of 100% can i just print the plan sheet out on my little printer and take to kinkos and tell them i need them enlarged to 100%
My Feedback: (33)
You should not have to print it first, just put on a floppy.
Kinko's has some weird rules as to which location can do what, but here the lady works the file/image to what I want. But I had to find a kinko's that would print large and had someone that knew what they were doing.
If your plan has a scale in it it helps a lot, but if You can call a home builder or engineering office thats works with blue prints, they can tell You who they use or maybe do it for You.
Kinko's is fairly expensive, here thay charge by the sq.inch and a 25 size plane plan cost Me $10 all on one sheet. 36x48"apx.
The can scan Your printed plan, but which way is better???
Dan Z
Dan Z
