RCM - April 1991 F-18 Article
Looking for a scanned copy of the construction article for Mike Pastro's F-18 in the April 1991 edition of RCM Modeler? If you can send it just pm me?
My Feedback: (15)
WI
RE: RCM - April 1991 F-18 Article
Send me your email address...I have all the RCM issues that had Mike Pastro's pusher projects.....the F18, the A10, T33, and the Canadian Snowbird plane....I can help you with that........
I love pusher aircraft and have built many different types....I always thought a large pusher F15 would be very doable
Tom
Tom
Not sure if the same, but contact Alex at AKM models as we did a set of laser cut parts for a pusher F-18 about two years ago. He should have the computer work on file too.
If the same, there are problems in the plan. A few things do not line up very well. Ask Alex for copy of (corrected) plan at same time.
Wm.
Wm.
FL
another way to go is jetsett44 (on rcgroups) he built a F-18 that was similar in construction BUT made out of Depron,.. it was gorgeous easy to build awesome to fly and inexpensive
Thanks for the information. I received a copy of the article from an RCU member last fall. Presently building the F-18 0.40 model.
Jim
Jim
For those of you interested the F18 article is available on line at [link=http://www.rcmmagazine.com/issues/requested/content/construction/pdf/r-cn-hornet-041991-1-1.pdf]RCM F18 Hornet Article[/link]
