Brakes for a "regular size" airplane.
GA
In the .25-60 range. I have seen a brake that had been made by Dubro in the past, but it's no longer available. Have you guys ever scratched one up or do you have any pictures of one? I wouldn't mind drawing something up and sharing it if all I get is pictures. The one I saw simply pushed a metal tab down on the wheel. That would work, but probably wouldn't do all that well on retracts! Any info you fellas can share would be very appreciated.
RE: Brakes for a "regular size" airplane.
sonic systems made a disc brake air operated that I installed on my jhh f9f cougar so that I could let the fan hit max rpm before starting the take off roll to cut down the distance.worked well.check with the jet guys as someone should be making a version of it.
ptulmer:
I ordered a set of wheels/brakes (2.4" diameter, air operated) from these guys:
http://s43500.sites99.storefront-hos...m/default.aspx
Kinda pricey, but if you need brakes for a performance or safety issue, it's worth it. I got the Trim Aircraft ones, which were $157 plus about $9 shipping.
I needed them because I have a high performance prop in the nose jet (F-4) and I fly it off a paved runway that's only 350' long.
