cad and plans
cad and plans
ok I downloaded a set of plans but does me no good as I don't have a CAD program. So I guess now I have to go out and spend a butt load on a CAD program? Are there free programs that will work for a basic airplane like an ugly stick?
SC
RE: cad and plans
Take the DWG or DXF file to a print shop. They can probably print it out for you at about the same price as if you purchased the printed plans to begin with.
Dr.1
Dr.1
RE: cad and plans
Depending on how educated the print shop personnel are, you may or may not be able to get them to print a .dwg or a .dxf file.
Try this: Create a pdf using CutePDF. You'll have to download this from the internet and install it. Any print shop with a wide format printer should be able to print a PDF file.
Creating the PDF: go to the Printer Setup menu in your CAD program, and select CutePDF as the printer device. Now you should have a wide variety of paper sizes to choose from. Select the one which will fit your plan.
For DeltaCad, make sure your print region is scaled 1:1.
When you execute print, it will ask for the filename of the PDF you want to create.
Check the PDF before you take it to the printer.
About scaling....
Include a ruler in your drawing, take a tape measure to the print shop and check your dimensions before you leave.
My print shop charges $.30/sq ft, so a 36 x 60 plan would cost $4.50
About scaling....
