Auto Cad Help
MS
Auto Cad Help
Your going to have actually draw the entities that make up your design in 3D. The only exception to that is if you drew your design in ISOMETRIC to start with, but that's still just a 2D view made to emulate a 3D viewpoint.
The only way to take an X-Y drawing and make it 3D is by modifying it with 3D commands such as EXTRUDE and REVSURF to name only two out of the dozens of 3D commands.
That's what the Z axis is for.
Or am I misunderstanding the question?
Highflight
Highflight
MS
Auto Cad Help
Unfortunately, you're trying to create something from nothing.
You cannot arrive at a true 3D object without representing (by defining them in the drawing) the full relationships between all three axis' (X, Y, AND Z) for all of the individual entities that make up your design.
For example, if you did something as basic as to EXTRUDE your 2D entity, it would simply end up as a 3D shape with the same outline, but with thickness. Think of it as a "Profile" model where you cut out a fuselage shape on your bandsaw out of 1/2" balsa. You end up with the desired outline shape, but it's simply 1/2" thick throughout.
EXTRUDE is probably the simplest 3D command to execute but it's only the beginning of drawing a true 3D object
I would suggest that you dig into the 3D tutorial of whatever CAD program you are using and follow through in whatever order the tutorial offers.
You will very quickly better understand that you can't get to where you want to go from where you're at.
Before you can go any further, you are going to need to acquire a more thorough understanding of how CAD works, both 2D and 3D.
You may then understand why I universally suggest to all new CAD users that, for designing model aircraft and drawing plans from which to build, they should forget about 3D altogether. There is no such things as "3D plans" from which you can build an aircraft.
ALL of the parts you need to build an airplane are defined by 2D design parameters.
Highflight
Highflight
Auto Cad Help
Probably the least painful method to 3D is thru RcCad..
You still have to add the 3rd dimension details, but it can work from a 2D image..
And it's inexpensive.
AutoCad is waaaaaaaaaaay expensive, for a hobby..
http://www.rccad.com/
This is the Gossamer Condor done in RcCad..
Auto Cad Help
RcCad doesn't output .dxf unfortunately.
It is somewhat limited for details like parts.
But it is a good introduction to 3D.
AutoCad, TurboCad and IntelliCad are better for drawing up parts for CNC stuff, but the 3D learning curve is STEEP!
And not of any particular use for plans which need only be 2D..
3D is nice for instructional views, such as this one, done in AutoCAD.
Auto Cad Help
............ anti- "anorexia" spars???????
BWHAHAHAHAHAhahahaha....ha...haha..........ha..... ...ha.........*cough*......
That's a good one. You won't see that one in any aerodynamics texts I'll wager. I'm just glad I didn't have a mouthful of dinner when I saw that
Filtr, if it helps any you need to understand that on your 2D drawing the part here is represented by a line over there. There's just nothing available to tell the program that this part is that line but rotated to fit vertically.
In 2D we draw parts and construction guides. In 3D you actually form and build the model in virtual space using 3 dimensions.
Hope that helps.
Hope that helps.
Auto Cad Help
Originally posted by BMatthews
... In 3D you actually form and build the model in virtual space using 3 dimensions.
Hope that helps.
Hope that helps.
And when rotating the drawing, it's amazing how many of the points so carefully placed are really over in Bakersfield, instead of where they looked like they were going in the original view!
Auto Cad Help
Hi Ron
I am in the middle of a new pattern plane project, which is my first using the computer and software and not a good old pencil and paper.
Although it's been a step learning curve it sure helps me visualize the end result.
What is it that you need to design/build?
I did my wings using Profili and all in 2D and my fuse plug in 3D using Rhino. The fuse plug is due to be CNC milled in two weeks time because the guy is so busy (and a modeler so the price should be a bit closer to earth.)
I have attached a pick of the plane modeled in 3D.
Ignore the colors, they are just meant to show the components. The blue is the canopy, the orange the belly-pan and the yellow the fuse.
Cheers
Katipo
Cheers
Katipo
SK, CANADA
Auto Cad Help
Hi Folks
I just got back from business trip. I was wanting to mold some landing gear and wheel pants for a kit.
Katipo the plane is looking real good. what did you use.
Ron
Ron
Auto Cad Help
Hi Ron
After messing about with auto cad and others I ended up with Rhino.
The CNC guys also use it and said that they normally don't have any problems with the files or the .iges files it produces.
But like with most software there is lots to learn and I have only just started.
Cheers
Katipo
Cheers
Katipo
Auto Cad Help
AutoCAD is fine if you want to spend a lot of time drawing something in 3D. What if you want to make a change? With AutoCAD it is painfully hard. SolidWorks is by far your best option for 3D modelling. You can make changes easily (because the model is live!), export 2D drawings for your workbench plans and it has good .dxf and .iges support if your lucky enough to have acces to a laser cutter. Sure, its expensive, but with some "creative" searching on the internet, you can find it for pretty cheap.
ON, CANADA
advanced 3d cad
creating & designing somthing with the aid of c.a.d. is quite a tedious process & is only worth it if u plan to use it create a mold etc for mass prodution. it is also mainly needed for free form compound curve designs. here is a pic of a plane that i am working on for the purpose of mass producing. this took about 25hrs of pure cad time to produce.
& this is still a draft design anyway
so only if u have a existing plane that u want to kit in fiberglass, thus laser scan the fuse & reverse engineer the cad form. leave it alone.
but however despite that if u got the software & the time its still quite a nice challenge.
anybody interested in my design by the way?
Auto Cad Help
reaaz:
Doesn't look bad, reminds me of Rutan's design for Beech (Raytheon) named "Starship."
But personally, I don't care for planes that fly "Backwards." Haw.
Bill.
Bill.
Auto Cad Help
Originally posted by katipo
I did my wings using Profili and all in 2D and my fuse plug in 3D using Rhino. The fuse plug is due to be CNC milled in two weeks time because the guy is so busy (and a modeler so the price should be a bit closer to earth.) Cheers Katipo
Profili is also excellent value when it comes to airfoil generation (and analysis). How can you go wrong at 10$U or whatever it is.
Katipo, Keep up the good work & please post some pics of your progress. My pattern days are behind me (sniff) but I am working on some cool stuff. To be continued....
