extra 300s (ryobi powerd)
hi all i decided to pick back up my design project. i am designing an extra 300s for sport flying only not 3D and i would like to power it with a ryobi 31. i may run it on glow gas to give me a bit more power and less weight. my question is would a 60" span plane be ok for this project or should i go bigger or maybe smaller? i probobly wont start building for a long time but it is fun to work on the design i will post pics once i get back home in a week. the plane will be built with an airfoiled tail and standard balsa and ply construction along with some fiberglass as well. this will be my first large scale design but i have been building for about 3 years and have lots of ameture cad experiance.
RE: extra 300s (ryobi powerd)
ok that will make things a little bit easier. i think i will go with 70" then.
did you run your ryobi on the stock magneto? or did you convert it to IE. also what prop did you use? i like apc if it matteres.
hi all as promised here is a pic of the plan i went with a 70" span. if any of you want a copy of the plan let me know i will send you the dxf file for it although it is not proven i would like the constructive criticizum
