Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
CNC foam cutter ?
Old 04-10-2003, 06:42 PM
1Jimbo
Default CNC foam cutter ?
I'm looking for a good CNC foam cutter. Should I build one or can a good one be purchased at a decent price?
Old 04-11-2003, 02:06 AM
thunderchief
Default CNC
1Jimbo,
check out this site
http://gm.cnc.free.fr/index_en.html
you can download the software and play with it for thirty days.
Also go to Tal`s site a link is listed he sells machines and kits range 700 to 800 dollars...you could probably built one for 300-400. Also check out site called hobbycnc.com
Glenn the thunderchief
Old 04-20-2003, 03:47 PM
bash-ace-RCU
My Feedback: (16)
Default CNC Foamcutter
1Jimbo, I'm in the same boat your in, looks like the best deal I have found if you don't want to build your own is the $800 package deal setup that foamlinx.com sells, it's even tested before they ship it out. Once I raise the $$$ I will order one, I already have the software and computer to run it.
