installing & aligning retracts in foam wing
I'm trying to figure out the best way to install a retract on FW190D9 that came with a foam wing (and fixed gear). I've got the mounting rails made, and now it's a question of aligning the whole deal.
As far as I can tell, I have 3 axis to deal with (looking at the LE of the wing):
1) Up/Down. The wing has some dihedral, but I've figured out how to ensure that both retracts will have the same angle w.r.t to the center rib.
2) Yaw left/ Right. This I've copied from my 3-view and should be not too hard to duplicate.
3) Roll fore-aft. Hard to do, I just have to ensure that both retracts have the same Roll.
My plan was to build a 3D template, where both retracts are 1 piece so that all the 3 axis are fixed. Use the jig to set the retracts rail in the wing and glue it in place... I'm just wondering if there was an easier approach...
Cheers,
-derick-
Cheers,
-derick-
I just mounted a set in a scratch built Curare.
I mounted the rails to the retracts. Got my center lines from the center section of the wing, the leading edge, and trailing edgde. I had pencil lines showing where the mounting blocks were going in red pencil. I cut the holes in the foam for the blocks with just a long razor knife. I put lots of 30 minute epoxy all over the mounting blocks, in the holes in the foam wing. I had the retracts in the extanded position so I could hold on to the strut to position them in the wings.
I then just eye balled the struts and wheel to make sure they were straight and the both struts had the same lean. I had a square I would put up to the leading edge and measure to see how far back the struts were. They would move a little until the epoxy started to cure. I would keep checking until the epoxy got hard enough to hold them in place.
I have read other ways to do it this forum. Some were so involved that I would have never put retracts in if I had to do it the way they stated.
Right or wrong that is the way I did it.
Dru.
Dru.
Dru,
I would suspect the "eyeball" effect would be simpler.. But hate to see what my expression would be if I realize too late that one of the blocks is off by "that much"....
I'm in the process of building a jig as we speak. I'll post some pics when it's ready...
Cheers,
-derick-
Cheers,
-derick-
for most individuals, you eye is a very accurate device when lining something up on a model., especially an item that does not lend itself to measuring easily.
If it looks right from the front ,side ,and rear, your usually good.
