Gorilla Glue and Vibration
I have used gorilla glue to plank a limited portion of a model from the bottom of the firewall to the first former. The area is seven inches wide by six inches long. You can see the area behind the engine and firewall in the image. It extends up to the leading edge of the landing gear. The planks are 3/8 by 3/16 inch thick balsa that wind up 1/8 inch thick after sanding. The model has been flown for about 100 hours with a Brison 2.4. I inspected the glue joints for degradation and have not noticed any. Is the use of this type of glue in a high vibration environment a sure failure?
RE: Gorilla Glue and Vibration
I have used Elmer's polyurethane glue on high stress, high vibration areas with no problems; on planes with over 100 hours of flight time. I have seen older epoxy joints shatter like glass if stressed.
I have dropped my 35# plywood PTB drop 4' onto a concrete floor and only had dented wood.
Titebond II. Most non-hitech glues, are very shock resistant.
Somewhere, I read that Epoxy keeps curing in hardness long after we are satisfied with it in 24 hours.
Sort of like Concrete.
Rich
ORIGINAL: cyclops2
Rich
Rich
