Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
RCM Ultra Sport 60 mods
Old 07-20-2008, 12:27 AM
mmattockx
Default RE: RCM Ultra Sport 60 mods
ORIGINAL: prgonzalez
Then stab, to save some weight, I decided to build it hollow too...
Not only will it be lighter, it is stiffer and much more warp resistant than a solid sheet structure.
Mark
Old 07-20-2008, 08:21 AM
dhal22
nice looking work. gotta love the magnetic building board.
david
Old 07-20-2008, 10:36 AM
prgonzalez
prgonzalez's Avatar
ORIGINAL: dhal22
david
Thanks.
Yes, I love the board. One of these days, I am going to buy one building set of supports from Paul @ www.airfieldmodels.com. For now, I have managed to work with the original supports and extra magnets.
Pedro
Old 07-22-2008, 10:40 PM
prgonzalez
prgonzalez's Avatar
Left wing is framed and shear webs are in place. Next step is apply LE. TE, and central sheating...
ID:	995960   Click image for larger version
Old 08-03-2008, 09:48 PM
ricassad
Just for you to know . Tower Hobbies has the kit again for $ 130.
Old 08-04-2008, 08:47 AM
  #31
prgonzalez
prgonzalez's Avatar
Ricassad,
Yes, thank you for the tip. However, I got the RCM plans and wood before the US60 was re-released by GP. At that time, I had another model on the building board.
I received the GP retracts this weekend and I bought the torque rods for flaps yesterday. So, my building will continue this week.
Old 08-05-2008, 07:33 AM
  #32
Kelsey_B
Regarding the split elevators. I feel setting the plane up with two servos for the elevators is so unnecessary. I have built two US 60's and used the wire joiner with no problems at all using the Harry Higley method. You drill the holes for the wire joiner over sized, fill them with epoxy, insert the wire joiner, and set the two ele. halves on a flat surface. I always used a little weight on top to keep them flat. The overszied holes means that they don't have to be precise, and the hardened epoxy will keep the wood from wearing against the wire. This plane does not need two ele. servos.
Keith
Old 08-10-2008, 09:33 PM
  #33
prgonzalez
prgonzalez's Avatar
I have installed the RW retracts mounting and wheel well. I am proceeding to the LW this week.
Regarding split elevators, I have decided to go with a one servo and a carbon fiber D.E.P.S.
Edited for correcting typos.
ID:	1008512   Click image for larger version
ID:	1008513   Click image for larger version
Old 08-25-2008, 08:26 AM
  #34
prgonzalez
prgonzalez's Avatar
I was able to continue working on the US60 this weekend. The LE is being roughly prepared for final sanding and shape using the LE template.
ID:	1018976   Click image for larger version
ID:	1018977   Click image for larger version
ID:	1018978   Click image for larger version
ID:	1018979   Click image for larger version
ID:	1018980   Click image for larger version
ID:	1018981   Click image for larger version
ID:	1018982   Click image for larger version
ID:	1018984   Click image for larger version
ID:	1018985   Click image for larger version
ID:	1018986   Click image for larger version
Old 09-03-2008, 08:27 AM
  #35
prgonzalez
prgonzalez's Avatar
I have finished sanding one wing. LE has been sanded to finish. Wing tip is also finished. However, I am not sure how rounded I should made the wing tip. I am working on finishing sanding the other wing. More to follow this week.
ID:	1025299   Click image for larger version
ID:	1025300   Click image for larger version
ID:	1025301   Click image for larger version
ID:	1025302   Click image for larger version
ID:	1025303   Click image for larger version
ID:	1025304   Click image for larger version
ID:	1025305   Click image for larger version
ID:	1025307   Click image for larger version
ID:	1025308   Click image for larger version
ID:	1025309   Click image for larger version
Old 09-03-2008, 10:10 AM
  #36
XTOL
XTOL's Avatar
Looks very good! I probably had my wing tips a little more
rounded than you have yours but not by much. Smooth contours
is the design philosophy of this plane.
When you are sanding the LE of the wing remember the contour
of the LE is different at the root than at the tip. Use the supplied
template off the plans and a long sanding bar.
Old 09-03-2008, 11:49 AM
  #37
prgonzalez
prgonzalez's Avatar
ORIGINAL: XTOL
Mike,
Thanks for the input.
Yes, I am using the LE root and tip templates for shaping the LE. Those long GP sanding bars are appropriated for the task.
Pedro
Old 09-11-2008, 10:58 AM
  #38
prgonzalez
prgonzalez's Avatar
Wow...I've have been having fun sanding both wings while trying to keep my working are free of balsa dust.
I am now touching up leading and trailing edges to obtain good symmetry between wing halves. I am also matching and adjusting the wings at root ribs preparing for joining the wings.
ID:	1030802   Click image for larger version
ID:	1030803   Click image for larger version
ID:	1030804   Click image for larger version
ID:	1030805   Click image for larger version
ID:	1030806   Click image for larger version
Old 09-15-2008, 12:10 PM
  #39
prgonzalez
prgonzalez's Avatar
After a forced break due to IKE, I am joining the wing halves and opening the wheel wells.
Edited to add more pictures.
ID:	1033939   Click image for larger version
ID:	1033940   Click image for larger version
ID:	1033941   Click image for larger version
ID:	1033942   Click image for larger version
ID:	1033943   Click image for larger version
ID:	1033944   Click image for larger version
ID:	1033945   Click image for larger version
ID:	1033947   Click image for larger version
ID:	1033948   Click image for larger version
ID:	1033949   Click image for larger version
Old 09-15-2008, 02:58 PM
  #40
prgonzalez
prgonzalez's Avatar
Completing wheel wells and test fitting retracts. Retracts alignment looks about right. It will require a minor adjustment. I will do it when I install the servo for the retracts.
ID:	1034036   Click image for larger version
ID:	1034037   Click image for larger version
ID:	1034038   Click image for larger version
ID:	1034039   Click image for larger version
Old 09-17-2008, 10:41 PM
  #41
ckangaroo70
My Feedback: (51)
ckangaroo70's Avatar
That looks fantastic![8D] Keep up the very nice work.
Old 09-18-2008, 09:14 PM
  #42
prgonzalez
prgonzalez's Avatar
Hi ckangaroo70,
Thank you for your compliments.
Here is the update. I have completed the installation of torque rods for flaps. I will continue with flaps, ailerons, and servo trays for ailerons, flaps, and retracts.
ID:	1035885   Click image for larger version
ID:	1035886   Click image for larger version
ID:	1035887   Click image for larger version
ID:	1035888   Click image for larger version
ID:	1035889   Click image for larger version
Old 09-25-2008, 10:07 PM
  #43
prgonzalez
prgonzalez's Avatar
For those following this thread, here is the update and pictures.
I took my time to think about the aileron servo trays. I made the decision to go with a design where the servo is almost flush with the airfoil.
ID:	1041005   Click image for larger version
ID:	1041006   Click image for larger version
ID:	1041007   Click image for larger version
ID:	1041008   Click image for larger version
ID:	1041009   Click image for larger version
ID:	1041010   Click image for larger version
Old 07-15-2009, 09:59 AM
  #44
prgonzalez
prgonzalez's Avatar
After almonst one full year, I am continuing this building. During this time, I have fixed the problems I had with my Giles 202 and its 0.90 engine that was giving me grief. Now that she is flying at its full potential, I have time to continue this new airplane.
So, I started the fuselage about two weeks ago. I am using laser cut part of a short kit that I purchase from lazerworks.
The original RCM US60 have an engine right/down thrust of 0/0. The GP version has 2/0. After much deliberation I decided to go with 2/0 because I am installing a TH-75 engine en I will not flying for speed but for pattern practice and maybe some competition.
ID:	1236761   Click image for larger version
ID:	1236762   Click image for larger version
ID:	1236763   Click image for larger version
ID:	1236764   Click image for larger version
ID:	1236765   Click image for larger version
ID:	1236766   Click image for larger version
ID:	1236767   Click image for larger version
Old 07-15-2009, 10:08 AM
  #45
prgonzalez
prgonzalez's Avatar
Two more modifications from the original plans will be pull-pull rudder control and DEPS. I have an idea of where to mount the servo for the elevator and am working on the way I am going to mount it just above and shifted forward from the rudder servo but easily removable for being able to access the rudder servo. (Ideas welcome). Because I have dual aileron control, the only interference I might have is from the flap servo and controls. So, I have to consider that. If I cannot find a solution for having both in place, I will opt for not having flaps. Pull-pull wire outlets are done.
ID:	1236777   Click image for larger version
ID:	1236778   Click image for larger version
ID:	1236779   Click image for larger version
ID:	1236780   Click image for larger version
ID:	1236781   Click image for larger version
ID:	1236782   Click image for larger version
ID:	1236783   Click image for larger version
ID:	1236785   Click image for larger version
ID:	1236786   Click image for larger version
ID:	1236787   Click image for larger version
Old 07-15-2009, 10:42 PM
  #46
prgonzalez
prgonzalez's Avatar
Today, I mounted the wing on the fuse to check clearances between servos for elevador, rudder, and flaps. My estimations tell me that I have enough space for doing all. So, I started working on the flaps and here is the development.
ID:	1237251   Click image for larger version
ID:	1237252   Click image for larger version
ID:	1237253   Click image for larger version
ID:	1237254   Click image for larger version
ID:	1237255   Click image for larger version
ID:	1237256   Click image for larger version
ID:	1237257   Click image for larger version
ID:	1237259   Click image for larger version
ID:	1237260   Click image for larger version
ID:	1237261   Click image for larger version
Old 07-19-2009, 08:55 PM
  #47
prgonzalez
prgonzalez's Avatar
Not much progress this weekend. I installed the wing dowells, canopy floor, and started with the cowl.
ID:	1240252   Click image for larger version
ID:	1240253   Click image for larger version
ID:	1240254   Click image for larger version
ID:	1240255   Click image for larger version
ID:	1240256   Click image for larger version
ID:	1240257   Click image for larger version
ID:	1240258   Click image for larger version
Old 07-24-2009, 09:08 PM
  #48
prgonzalez
prgonzalez's Avatar
I completed the center sheeting of the wing bottom section and spent some time installing the retracts servo. Then mounted right retract and tested servo travel for a perfect fit. No binding end to end.
ID:	1243066   Click image for larger version
ID:	1243067   Click image for larger version
ID:	1243068   Click image for larger version
ID:	1243069   Click image for larger version
ID:	1243070   Click image for larger version
ID:	1243071   Click image for larger version
Old 07-25-2009, 04:22 PM
  #49
chip_MG
My Feedback: (14)
Wow,
Glad to see the Ultra sport is still being built it is a super flying ship. I built two of these from the RCM plans when they first came out. One I gave to a friend of mine who did not like to build. I still have and fly mine after more than allmost 20 years.
Here's a pic of it with my Son in 1995 Austin Tx, ARCA field. Has a .61 MDS which hulls is fine.
Rather than find a cardboard tube, make your own sleve from 2oz fiberglass. Doing it this way will give you an incredably good fit.
ID:	1243400   Click image for larger version
Old 07-25-2009, 04:27 PM
  #50
chip_MG
My Feedback: (14)
Opps, The sentence about FG does'nt apply, Pasting error Ok sorry I try not to confuse
