Need Help!
MI
Need Help!
I'm designing a slope glider, and would like to have the wings removable for transport. The plane will have a split wing/shoulder mount type wing. I have not ever had the pleasure of seeing a set up like this in person, so I'm confused on the best way to get this done.
Thanks for any help.
Bandit 557
Bandit 557
RE: Need Help!
It is typically done using wing tubes. Here're a few threads, but I'm sure there are more here at RCU if you search:
http://www.rcuniverse.com/forum/m_36...tm.htm#3709699
http://www.rcuniverse.com/forum/m_61...tm.htm#6195657
http://www.rcuniverse.com/forum/m_29...tm.htm#2995853
http://www.rcgroups.com/forums/showt...light=2+piece+
David
David
MB, CANADA
RE: Need Help!
wow, i really wish that my searches could have pulled up those threads b4 i started my stubby build! alot of good reference material.
on my build "stubby from RCM plans" i used brass tube for the sleeves, and a carbon arrow shaft for the rod. alot lighter, and plenty strong for a 40 sized bird. plus, it hasnt cost me a whole lot either. only about $15 for materials.
good luck with your project,
andrew
andrew
RE: Need Help!
This topic is already running in the Sailplanes forum. One thread on the same subject at a time as per the rules please.
Thread closed. Please continue this in the other thread....
http://www.rcuniverse.com/forum/m_7964857/tm.htm
