Frise Ailerons
Frise Ailerons
Greetings,
I am working on my first build from plans only project. I have hit a road block. The plans indicate frise style ailerons with the gap at the underside of the wing. Two questions: How and where do I hinge these? What about the gap, won't the gap cause fluter? Anyone have any words of wisdom?
bowmaker
bowmaker
NH
Frise Ailerons
The Frise aileron was designed so that the bottom front edge of the upward moving aileron will be under the edge of the wing to cause some drag on that side of the wing. Almost like putting differential in the ailerons.
They hinge fairly deep in the aileron on the centerline. The gap will not flutter as the top skin should overlap the upper side of the aileron by as much as 1/2" depending on the size of the plane.
If you spend some extra time looking at the plans I think it will become clerer to you just how they work.
Hope that helps
Hope that helps
SD
Frise Ailerons
Frise alierons are a great system, and I plan on using them in my piper meridian.
You need to mass balance your ailerons, and hindge them along the cambered side of the airfoil. The gap wont be a problem once you connect the aileron to the control horn and balance the aileron.
Balance the aileron.
I do not have a graphic on me at this time, but perhaps in a few hours
Frise Ailerons
ThunderAI:
Thanks for the response. As I am new at building please forgive my ignorance, but how does one mass balance an aileron? How does balancing an aileron in such a way eliminate conrtol surface flutter?
Bowmaker
Bowmaker
SD
Frise Ailerons
Originally posted by bowmaker
ThunderAI:
Bowmaker
ThunderAI:
Bowmaker
Fluttering is reduced, because the aileron is no longer out of balance.
Frise Ailerons
ThunderAI:
Thank you. However I still have a problem in that the plans show the angle of the leading edge of the aileron to be reversed to your illustration and with the trailing edge of the wing straight cut with no angle. I think I willprobably re-work the configuration of wing and aileron to match your illustration. It seems to make more sense. Unless of course you have any other suggestions that might help.
Bowmaker
Bowmaker
SD
Frise Ailerons
If you are going to mass balance your aileron this will be about the only way to do that efectivly.
Do a search on the internet. You'll get alot of information on frise and possible layouts. The layouts can be almost without end. And as long as they are mass balanced then you can almost eliminate fluttering.
Here is a link on helping to get the servo linkages correct
http://home.att.net/~j.m.allain/SkyH...oAdverYaw.html
