.90 SIZE OF UGLY STICK PLANS
RE: .90 SIZE OF UGLY STICK PLANS
I took a .20 sized and just doubled them. My old Saito 1.20 pulls it just fine. The design is simple enough to just use a straight edge and ruler to double the size.
If you took the planes for a 20, 40, or 60 size and re-sized them in a CAD program, that would work too.
Dru.
Dru.
IN
Swamper ... [link=http://plans.rcmodell.hu/plansport.html]Here's[/link] a link to a free plan site (sticky at the top of this forum). Scroll to the bottom for a .60 DUS plan.
-MA
-MA
I have some of the 60 Jensen Ugly stick that are formated for enlargement
I am currently building a 150% model to be powered by a ST 2350.
I'll send them this evening to you.
Ok couple quick questions now that I have plans, I have the GP electroStik and has a straight wing and one set of plans has nothing about putting in dihedral but the other set has 1 ½” of it, should I just make it straight ? and the second question is engine should I run the OS .91FX ringed or the Super Tiger G-.90 ? ST is $100 less but is the OS worth the $100 over the ST ???
I would decrease the dihedral to 3/4" or 1" under one wing tip, I have an ST 90 and I'm
very happy with it, runs with the best of them, I also have a Magnum 90 that is an almost
direct copy of the OS engine and it is very reliable, guess engine wise it's what ever flies
your fancy the most.
I would only go with approx 75" wingspan max on the stick though as it has a very deep profile
and wide cord.
Bill D.
and wide cord.
Bill D.
ORIGINAL: Bill Diedrich
[email protected]
